Misfire in Cylinder 1
Old January 17th, 2010, 04:30 PM   #1
John's_stang is on a distinguished road
ok so my 2000 gt started shakin and buckin bad the other day so i took it to the local autoparts store to get a code and it says misfire in cylinder one so i pulled the plug and it has a mixture of oil and water on it...
can anyone help me with what this means
Old January 17th, 2010, 04:43 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
is it on the actual electrode or just the porcelain section the the COP mounts on top of. if its on the part the COP mounts on then you probably just got water leak in there from washing your car/engine so something
BUILD 2 IN PROGRESS
Old January 17th, 2010, 04:46 PM   #3
Bignastyxl321's Avatar
2000 Mustang Gt
Bignastyxl321 is on a distinguished road
intake gasket might be leaking.....was it on the bottom of the plug?
Low Et's is A Good Day
Professional Products Throttle Body
Professional Products Plenum
Ford Racing intake manifold
BBk Cold Air Intake
Steeda Short Throw Shifter
BBk Off Road X-Pipe
Sniper Tuning Software
Eibach drag launch kit
Old January 17th, 2010, 04:48 PM   #4
it was on the cop and on the plug... i looked into the cylinder hole and saw a water oil miture ontop of the cylinder
Old January 17th, 2010, 06:52 PM   #5
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
clean it and dry it out, replace plug and see if it returns
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old January 17th, 2010, 09:15 PM   #6
turbot4's Avatar
R.I.P.
twin screwed!!
turbot4 has a spectacular aura aboutturbot4 has a spectacular aura aboutturbot4 has a spectacular aura about
iTrader: 9 reviews
i'm getting a misfire on cyl 5 in my sho...i know my problem is a bad cop...
wonder if your having the same issue...
but like op said..
clean it and dry it out and or replace plug..still acting up check the coil..
Old January 17th, 2010, 10:27 PM   #7
yeah i blew it out with some air and dried the plug stuck it back in... started doin it again... my pipes are smoking out one side and not the other.. i believe its a blown head gasket
Threads Similar to: Misfire in Cylinder 1
misfire cylinder #6 hellbred07 2005 - 2010 11 April 20th, 2009 09:40 PM
cylinder 3 misfire pavementpownder 99-04 1 April 3rd, 2009 07:50 PM
Cylinder Misfire!!!!! ivan48humble 2005 - 2010 4 January 17th, 2008 06:57 PM
cylinder #8 misfire tallman20 General Tech 4 October 14th, 2007 04:11 PM
cylinder 6 misfire Jucostud 96-98 4 May 10th, 2007 11:46 PM
