Shaving Brake Caliper?
Old January 17th, 2010, 08:18 PM   #1
MyGT's Avatar
13.1@105
MyGT has a spectacular aura aboutMyGT has a spectacular aura about
iTrader: 7 reviews
I'm looking to put skinnies up front on my car. How would I go about shaving the brake caliper down?
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees!
Old January 17th, 2010, 08:22 PM   #2
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
What calipers do you have?
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old January 17th, 2010, 08:22 PM   #3
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
generally it's not the caliper it's the bracket you'll have problems with. if you take off the wheel you'll see the lower part of the bracket that hangs below the caliper & sticks out a little further than it, thats what usually what needs cut off.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 17th, 2010, 08:24 PM   #4
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
+1^ the gt calipers are what I'm refering to, cobra/mach 1/bullit, will require more work depending on the wheel's you choose.
2012 300a GT auto
Old January 17th, 2010, 08:26 PM   #5
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
angle grinder like the the one you see on orange county choppers... they use it for everything. i have one and i call it my occ universal tool
Old January 17th, 2010, 08:51 PM   #6
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Angle grinder. We had to shave a good bit off to get my buddies slicks to fit on his lightning.
Old January 17th, 2010, 08:54 PM   #7
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
if its stock and you get jegs, you just need a 1/4 wheel spacer
Old January 17th, 2010, 08:57 PM   #8
MyGT's Avatar
13.1@105
iTrader: 7 reviews
They're welds, and sorry guys I mean't the bracket haha.
I have a set of 3/8" spacers, would they work without modifying the bracket?
Thanks Brees!
Old January 17th, 2010, 08:58 PM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
talk to mrbigjeep, he just put some on his
Old January 17th, 2010, 09:06 PM   #10
Giggle Juz's Avatar
Giggle Juz will become famous soon enough
i have the same front skinnes as f8l gt and all i did was grind a 1/8 inch off caliper bracket and it doesnt even rub.
Old January 17th, 2010, 09:22 PM   #11
MyGT's Avatar
13.1@105
iTrader: 7 reviews
so a 3/8 spacer should clear fine?
Thanks Brees!
Old January 17th, 2010, 09:23 PM   #12
Giggle Juz's Avatar
i dont use them no need.
Old January 17th, 2010, 09:26 PM   #13
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
here
Originally Posted by mrbigjeep View Post
well i got them on...look pretty sick i must say. and i did a straight trade so got them with no money involved
and the fronts did NOT fit even with a 5/16" spacer...we had to cut the bar on the caliper bracket off and use the spacer which thank goodness i picked up just in case (15 bucks for both at pep boys )
i will probably order the 3" wheel studs and knock them in when i get a chance...sure wouldn't hurt to have the added strength and espcially with the spacer up front
Old January 17th, 2010, 09:30 PM   #14
Giggle Juz's Avatar
easy killer my are just fine without them have had no problems.
Old January 17th, 2010, 09:33 PM   #15
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Gig, jegs wheels are different than welds
Old January 17th, 2010, 09:35 PM   #16
Giggle Juz's Avatar
my brother has welds on his mustang we did same thing and my buddy has them on his lightning same way.
Old January 17th, 2010, 09:36 PM   #17
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
depends on what he has, unlike jegs, welds can come in different back spacings
Old January 17th, 2010, 09:37 PM   #18
Giggle Juz's Avatar
does he know what the back spacing is?
Old January 17th, 2010, 09:47 PM   #19
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
JayC ended up cutting his caliper bar right off
Originally Posted by JayC View Post
Cut the caliper bar and be done with it
Old January 17th, 2010, 09:50 PM   #20
Giggle Juz's Avatar
thats also a centerline not a weld or jegs. whats the back spacing on your wheels?
Threads Similar to: Shaving Brake Caliper?
I got 94 brake caliper brackets but.... 5.0 street stanger 5.0 Mustangs 5 June 27th, 2009 12:56 AM
Need Help Replaced Brake Caliper 01 GT 99-04 1 December 15th, 2008 08:22 AM
Brake Caliper Paint? ECUSVT31 4V / SVT 21 July 20th, 2008 11:48 AM
how to change brake caliper mm49271 V6 Mustangs 2 July 19th, 2008 05:16 AM
brake caliper problem burnout5.0 94-95 3 October 4th, 2007 12:38 AM
