#21 | |
99 limited edition vert
taking material off the cc will lower cr but not a extreme amount(you won't get a point out of it) you probably can gain a .5 or so from a polish on cc and thicker gasket,anymore you need to change pistons. there are several calculators avail. online to play with, just google them
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#22 |
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
Well I did what limited said and did a few online calculators. I put in stock bore, stroke, deck height, head gasket thickness and bore, and the dish of my piston and got an average of 10.67:1 compression ratio.
Then I added 2cc, a reasonable amount of material to be removed during polishing, and doubled up the head gasket thickness and it brought it down to an average of 9.51:1 on all the calculations I tried. I didn't think it could make that much of a difference but apparently it does!
Do the Right Thing, Cook. ~Zip. |
Threads Similar to: Compression for boost?
| can i boost high compression? | skuba | Modular Mustangs | 10 | October 12th, 2009 04:01 PM |
| Low Compression High Boost? | e3sean | 5.0 Mustangs | 19 | November 19th, 2007 01:13 PM |
| compression? | matfernan1 | 99-04 | 5 | August 30th, 2007 11:42 PM |
| 20 lbs of boost in a v6? compression ratio? | camaroandjeep | V6 Mustangs | 6 | January 11th, 2007 11:13 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
