Baker Jr.
Compression for boost?
Whats a good compression range for about 18-22lbs of boost, I found a guy selling a forged shortblock with 8:9:1 compression.
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
I Blumpkin Entirely Way Too Much
2005 Mustang GT
Thats about right i think. what kind of power adder? because with a centri they usually say 9.6 and lower. so you should be right in line i think
MM + Cleavage member #22
Baker Jr.
Procharger! Sounds good!
Baker Jr.
Whats cheapest way for him to ship it to me you think guys?
Hooo Ha Ha
8.9 should be about right for your aplicatio
UPS ground. Probobly will be fairly expensive but can be done im pretty sure they do that stuff all the time Im right around the corner from you. Have you seen my stang around?
![]() 410rwhp 520rwtq @ 12.9 psi |
Baker Jr.
Na not yet we should meet up one night and go prowlin tho!
Hooo Ha Ha
Will do once I get my her fixed hopefully tommarow. Do you ever go cruising in the glen burnie area? Richie highway. Its so fun to mess with the ricers down there.
I-97 can be fun to cruise on aswell
1999 3V GT/2007 GT D/D
corner carver
I am at 9.5:1
OS2 (SW) USNREAR SEAT DELETE FABRICATOR "RSD pics in garage" 99 3V GT/2007 GT DD |
Baker Jr.
Ya ive been on richie, im only 19 and have a point on my license and have to make it till june so i cant get no tickets or i lose my license and job for 6 months so i gotta watch it but ill still run it lol. Ill have to come up to richie hwy sometime soon when you go and meet you some where and chill, ill bring my chick and we can race some people and eat or something and chill!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
i hope this isnt the one with the big ass gouge in the cylinder?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
Hooo Ha Ha
Well im 17 and havnt been caught yet but I know where your coming from bro.
Hell yea im up for that though. I normally run a radar detector and have my gf on cop watch haha. Theres tons of food places down there aswell.
12.35@114.08 w/ 1.88 60'
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 7 reviews
I think around 9-9.5 is good for centri and 8.5 is good for roots/turbo.
What is the best way to lower a compression ratio without changing rods/pistons? Say if I wanted to lower the CR on an engine from 10.5 to 9.5. The two headgasket thing isn't going to make that much of a difference, so forget about that. Can material be safely removed from the combustion chamber on our PI heads? Is there an easy way to check the compression ratio of an engine? Or do you have to do the thing where you use a graduated burret to check volume at bottom dead center, at top dead center, and the volume of the combustion chamber of the head and then do BDC+CC divided by TDC+CC?
Do the Right Thing, Cook. ~Zip. |
Also I've heard that cam profiles play a part in the dynamic compression ratio... any truth to that? If I had a wicked cam could I swap it out for a milder one and be able to run more boost?
02 Mustang GT
9.91@133
My c/r is about 9.5. Yes cams can change the dynamic compression.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
#15 | |
Do you know how? EG does less lift and duration mean lower dynamic compression? Does lobe separation have anything to do with it?
02 Mustang GT
9.91@133
damn you y2k, i was hoping to get cliffnotes on this stuff not links to full articles!
haha, i'm so lazy... time to read up I guess ![]() EDIT: That link is great. I'm really glad I read through it. Basically it says that the more intake duration your cam has, the higher your static CR can be... It makes sense because compression doesn't really start until the intake valve is closed, and that is not at bottom dead center (which is how static CR is measured)
Do the Right Thing, Cook. ~Zip. Last edited by dcook_14; January 18th, 2010 at 01:31 AM. |
#19 | |
well cook... thats a tough question cause you are eliminating everything that decides compression. lol... Ported heads lower it i think.
Threads Similar to: Compression for boost?
| can i boost high compression? | skuba | Modular Mustangs | 10 | October 12th, 2009 04:01 PM |
| Low Compression High Boost? | e3sean | 5.0 Mustangs | 19 | November 19th, 2007 01:13 PM |
| compression? | matfernan1 | 99-04 | 5 | August 30th, 2007 11:42 PM |
| 20 lbs of boost in a v6? compression ratio? | camaroandjeep | V6 Mustangs | 6 | January 11th, 2007 11:13 PM |
| Turbo Boost vs Super Boost | droppedbass87 | General Tech | 12 | October 16th, 2006 09:56 AM |
