belt routing help please
Ok so I went off of this diagram, Chad's 2000 Mustang GT American Racer -- 4.6L Accessory Belt Routing and with the cams install now and all the lights on and the max ac on the battery light is flickering. I just put on a new idler pulley and belt (gates from napa). Did I maybe get the idler pulley to tight? Routed wrong? Car is an 01. Never noticed the light flickering with the stuff all off and running under no load with the cams.
![]() 375hp 380tq Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper vids http://www.youtube.com/user/01mggt Mineral Grey Club member #14 Military Crew E-4 Predator Crew Chief Holloman |
!FACEPLATED!
thats the correct routing.
what the problem could be
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
!FACEPLATED!
maybe your alt is starting to go out. You sure you connected the wire to the alt tight?
yup it's tight.Never had an issue before with it till jsut now. Car has less than 56k on it
Threads Similar to: belt routing help please
| Short belt routing???? | kilby91 | 5.0 Mustangs | 14 | September 2nd, 2009 10:35 PM |
| re routing belt | djh1286 | V6 Mustangs | 9 | October 26th, 2007 12:19 AM |
| A Few Questions (Belt Routing) | 83five0 | 5.0 Mustangs | 20 | May 4th, 2007 11:26 PM |
| 5.0L NO A/C NO SMOG NO P/S BELT ROUTING | sstone | 5.0 Mustangs | 4 | February 7th, 2007 01:06 AM |
| Alternator only belt routing help??? | lxracr | General Tech | 0 | June 25th, 2006 08:21 PM |
