2004 Cobra
Need help with drivetrain play
So here is the deal i payed some one to install 4 10 gears in my car about a year ago, now it makes a loud clunk when i shift. Any time i shift or let off the gas and hit it again it clunks in the driveshaft. i put the car up on jacks and found that there is a lot of play in the driveshaft. all the u joints seemed fine so it has to be the gears right?
well my question is is there anyway to adjust the gears without having to pull it all apart and shim ( which i have never done before)? any info would be helpful here not sure what to do. a side note i would guess the the extra power from the supercharger would cause the rear end to wear so fast? one last this feel free to chime in on if i should drop down to a 3 73 gear bc i have the supercharger now. if i have to pull it apart again might just do it.
2004 Mystichrome Cobra - stiegemeier ported blower, acufab mono blade throttle body, 2.80 pulley, snub and idler pulleys, bassani mid lengths, bassani or x and bassani catback with baffles removed, k & N drop in.
2003 Mustang GT
14.03@100
W/ a centri blower like Vortech, you don't need to drop down. Having the steeper gear would actually be better to help get you to the "meat" of the powerband.
#3 | |
2004 Cobra
![]() con just don't like the idea of ~110 in 4th topped off pro fun as hell to mess around in
2003 Mustang GT
14.03@100
Well that's what you get for having a great set of gears for "off-the-line" performance. Did you take your speed limiter off w/ a tuner?
2004 Cobra
^ yes but i don't wanna push over 6k rpm
#6 | |
99 limited edition vert
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2004 Cobra
^i can turn the driveshaft almost 1/4 turn before the wheels turn.
pull rear cover and inspect is my suggestion
Threads Similar to: Need help with drivetrain play
| slack in drivetrain | justin025 | 96-98 | 12 | May 7th, 2009 04:19 PM |
| lightning drivetrain in a '72 | haywood11 | Classic Mustangs | 9 | February 12th, 2009 07:51 AM |
| What would the value of this drivetrain be? | Matt300ZXT | 5.0 Mustangs | 6 | November 20th, 2008 09:46 PM |
