Comp 270's ok with boost?
Old January 18th, 2010, 01:20 AM   #1
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
I already have comp 270's and was wondering how well they work with some boost.
Old January 18th, 2010, 01:26 AM   #2
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i know a guy that ran them with his 70mm turbo and he didn't hit full boost till 4k or higher...i mean they will work but they definitely aren't the best thing for a boosted motor. i mean they are a n/a cam.
stock cams would hit full boost around 3500-3800
cams + 150 shot
Old January 18th, 2010, 01:29 AM   #3
Willy Mo's Avatar
well i have yet to install the cams.. waiting on other parts and do the install all at the same time.. but am goin with boost eventually
Old January 18th, 2010, 01:50 AM   #4
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
they will be ok...but not the best choice...i wouldn't doubt it if you regret it once its time for boost
cams + 150 shot
Old January 18th, 2010, 01:54 AM   #5
mounder27's Avatar
02 mustang gt
6.92 @ 99 mph 1/8th
mounder27 will become famous soon enough
They will work fine for supercharged apps, now turbo is a different story all together, the cams need to release more exhaust sooner to be reach peak efficentcy for the turbo to spool up
www.wmdracing.net
Old January 18th, 2010, 01:54 AM   #6
Willy Mo's Avatar
well a turbo is what I will be going with
Old January 18th, 2010, 01:56 AM   #7
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
even more reason not to get them lol...as the guy i was referring to has a 70mm turbo.
cams + 150 shot
Old January 18th, 2010, 02:02 AM   #8
Willy Mo's Avatar
yeah i mean i have had the cams for a while but was waiting to install them. now i am pretty sure i am getting a T-66 turbo.
Old January 18th, 2010, 10:11 AM   #9
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
Just get something like MMR Turbo cams. How much boost you lookin' to run?
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old January 18th, 2010, 04:32 PM   #10
Willy Mo's Avatar
well the bottom end is stock.. so until I beef it up it wont be to high.. 10# ish...
I will be picking up the turbo this weekend.... And what do you all think about fabricating some custome turbo headers?.. I found a site that has the tubing and even has the heagder flange for the 4.6
Old January 18th, 2010, 04:51 PM   #11
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
I have the whole hotside, h-pipe and magnaflow magnapack exhaust for sell, but you would need two turbos.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old January 18th, 2010, 05:44 PM   #12
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
Get the MMR stage 1 Turbo cams or Stage 2 Turbo cams
Old January 18th, 2010, 11:02 PM   #13
Willy Mo's Avatar
yeah i guess I will be selling my brand new comp 270's.. and will be looking at some turbo cams..
but what about the custom turbo headers idea? think its worth it? or should I use the stock manifolds?
Old January 18th, 2010, 11:08 PM   #14
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
i would just use stock manifolds...you are gonna have all the horsepower your stock shortblock can take anyway even with the stock manifolds...
and if you get a built motor you can just throw a set on then if you want when everything is out and apart...
JMO
i dunno about a 66mm but on 10lbs and a 70mm i know most guys are hitting the limit of what you would wanna push the shortblock to. and thats on stock motor
dude on here has 70mm and hit 400 on 8lbs...and other dude i referred to earlier hit 425 on 8lbs with the comp 270's.
cams + 150 shot
Old January 18th, 2010, 11:12 PM   #15
Willy Mo's Avatar
well then itwill be a max of 8lbs.. or what ever is close to 400whp.. until a built bottom end goes in..
and its a Turbonetics T-66, Q trim, A/R 1.00, and is rated to 900hp
Old January 18th, 2010, 11:15 PM   #16
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
8lbs would probably put you very close to 400...like right on. unless you need more boost with a smaller turbo...not sure. just sharing what i have found about the 70mm..
anyway, good luck
cams + 150 shot
Old January 18th, 2010, 11:18 PM   #17
Willy Mo's Avatar
thanks... anyone know where I can buy a good t3/t4 flange to weld the hot side piping to?
Old January 18th, 2010, 11:45 PM   #18
Mustang GT
2000ZincGT will become famous soon enough
ebay
Stock.....
Old January 18th, 2010, 11:48 PM   #19
Willy Mo's Avatar
well I found this site
Merge Collectors True Merge Collectors
could get mostof the hot sideparts from here.. fairly reasonably.. But another question would be.. better to gowith a blow through MAF?
Threads Similar to: Comp 270's ok with boost?
Pi heads with comp 270's MeMz Videos 0 May 28th, 2009 08:14 PM
VT Blower Cams Vs Comp 270's 97GT4.6 96-98 13 December 16th, 2008 04:42 PM
Gas Mileage With Comp 270's? Schraders 99-04 11 August 12th, 2008 03:53 PM
