homemade shifter modifications - Page 2
Old January 22nd, 2010, 06:18 PM   #21
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
Originally Posted by stangman92 View Post
well it is a given though that by making the actual length of the shifter shorter, ur creating shorter throws, simple lever and fulcrum point. And as for shift stops, the 3650 has internal shift stops. but yes, the springs are definetaly stiffer on an aftermarket shifter.
the internal shift stops on a 3650 suck balls and allow you to easily bend shift forks with a missed gear whereas i have beaten the hell out of a 3650 with a upr blue thunder with adjusted shift stops and had not problem. there is more to a TRUE short shifter than just a shorter handle is all im saying.
Old January 22nd, 2010, 06:25 PM   #22
2002 mustang GT
stangman92 is an unknown quantity at this point
yes of course, you are 100% correct that a true short shifter ahs mroe than just a shorter handle, but for the money (free) i make do with mine, if anyone wants to donate one, i would appreciate it jaja
Old January 22nd, 2010, 11:32 PM   #23
redFireGT's Avatar
2003 Mustang Gt
redFireGT is on a distinguished road
Send a message via AIM to redFireGT
seems like it would be easier to just buy a short throw haha
Old January 23rd, 2010, 01:59 AM   #24
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
I had a mac shifter on my orginal t45 then when I installed the tr3650 I used just the handle on the tr3650.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 23rd, 2010, 11:01 AM   #25
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
you do know that when you weld something, the weld is stronger than the metal itself.
Not quite... If you are good at welding, then the welds will be stronger. If you're not the greatest at welding, I guarantee the shifter will break at the welds before the acutual handle breaks. Plus an aftermarket shifter is almost always aluminum, which has to be TIG welded, which is probably the hardest type of welding.
Originally Posted by mystang0673 View Post
when people think short throw shifter they think it is shorter therefore making the shift shorter which is not true... a short throw shifter adjusts the actual distance that the shifter moves. they also have adjustable stops where the stock ones dont. and as stated above, the springs that push the shifter to nuetral position are much better than stock. and i believe that the upr blue thunder has the hardest spring...
+1 Well said
Do the Right Thing, Cook. ~Zip.
Old April 21st, 2010, 05:33 PM   #26
nathanielwilliam's Avatar
2001 Mustang GT
nathanielwilliam is on a distinguished road
The strength of the weld depends on the temperature of the weld and the cooling process. Doing a post weld heat treatment really helps the strength of the weld as it allows residual stresses caused by welding to go away. To do a PWHT, either cover the part with insulation after you finish welding it so that it cools as slowly as possible or heat the part up in something and slowly lower the temperature. usually over the course of an hour or two.
Of course, it should be noted that welding on some steels, the carbide phase of the carbon in the steel will be converted to graphite (I think this occurs at about 800F). Some alloys can also be ruined by welding on them or simply getting them too hot.
2001 Mustang GT
short throw shifter
4:10 gears
3 inch dual exaust (no cats!)
I have an F-150 which I drove the balls out of for seven years. Now I have a mustang that I drive the balls out of also.
Old April 21st, 2010, 06:56 PM   #27
slikirish's Avatar
2004 Mustang GT 5spd
slikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the rough
holy dead thread batman
Mods in Garage
Threads Similar to: homemade shifter modifications
Homemade PB FTW JASonic The Clubhouse 9 February 28th, 2009 05:36 PM
Homemade mils? PwGT 99-04 10 September 4th, 2008 07:18 PM
How To Make a Homemade Taser Breakout The Clubhouse 21 January 22nd, 2008 12:50 AM
