Axle swap question
Old January 24th, 2010, 10:22 AM   #1
01V8MUSTANG's Avatar
01V8MUSTANG is on a distinguished road
Axle swap question
So I picked up a rear for my '01 Mustang from a turbo coupe. I need to know if I can swap my 5 lug axles from my 7.5" rear over to the 8.8" rear? Also will the disc brake setup from the turbo coupe work with the 5 lug rotors?
Old January 24th, 2010, 09:04 PM   #2
Nobody? Anybody?
Old January 24th, 2010, 09:05 PM   #3
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
no. axle length is different and i dont think the axles will fit in the diff.
Old January 24th, 2010, 09:08 PM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Im confused. Your name says you have a V8 but you have a 7.5" rear? did you swap out a sixxer for the 8?
Old January 24th, 2010, 09:20 PM   #5
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I'm confused why the OP would have a 7.5 and a V8 too...
But I'm almost positive the axles would not fit the side gears in the 8.8 carrier correctly
Do the Right Thing, Cook. ~Zip.
Old January 24th, 2010, 09:49 PM   #6
I8ACMRO's Avatar
2003 Mustang GT
14.03@100
I8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura aboutI8ACMRO has a spectacular aura about
Either he must've done a V8 swap or he is just REALLY confused as to what was in his car...
http://www.moddedmustangs.com/forums...-member-30498/
Originally Posted by RZNCAIN View Post
Drive the shit out of it and replace shit when it breaks. No point in having these things if we are going to drive them like a bunch of pussies!
Old January 24th, 2010, 11:20 PM   #7
Hahahaha! Absolutely no confusion here, I'll break it down for you:
car: 2001 Ford Mustang
engine: V6 3.8L/auto(factory)
rear: 7.5"
mods: V8 swap in progress,trans swap inprogress, rear swap in progress
V8 is stock for now, will make 450ish rwhp by summer 2010.
Didn't realize my post was so confusing. No I didn't say what V8, don't want any more confusion.
Old January 24th, 2010, 11:22 PM   #8
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
ahh ok, by your name i thought you had a GT. your best bet would be to get a 8.8 out of a 99-04 gt and directly swap it in. you can do a 94-98, but i do believe it will suck the back tires in a little more because the axles are a little shorter
Old January 24th, 2010, 11:27 PM   #9
OK, thanks. What do most guys use when doing the 5 lug conversion? I have a set of 4 lug rims I can use for now, but want the 5 lug eventually. I read that some guys use the longer axle from 2 Ranger rears, is that a possibility? Ranger and Explorer rears seem to be in abundance around here.
Old January 24th, 2010, 11:35 PM   #10
I was looking for a rear out of a 99-04 but couldn't find one reasonable in price(I'm on a REAL tite budget). I was considering the 94-98 because they were narrower, just couldn't find one either, this would work well because I am planning on running some 17x10.5(maybe wider)rear wheels.
Old January 24th, 2010, 11:36 PM   #11
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Your right, the SN95 axles are shorter, 1" if I remember correctly.
Old January 24th, 2010, 11:37 PM   #12
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
FYI, a 17x10.5 will fit fine with a 99-04 rear also
Old January 25th, 2010, 08:25 AM   #13
66mustang03gt's Avatar
03 mustang gt
12.00
66mustang03gt is on a distinguished road
just be patient, 8.8 rear ends are plentifull out there, and good prices too. the 99-04 will fit 17x10.5 rims and use a 315/35/17 tire, its the same exact size as the stock 245/45/17 tire height so it wont screw with your speedometer at all.
Imports are like tampons, only PU$$Y's use them!!!
Old January 25th, 2010, 09:35 AM   #14
Ya, patience is not my strong point when it comes to my projects. Should be picking up motor/trans wext week, rear this week, then I still have to pull the v6/auto out. Anybody in eastern PA need a 3.8/auto trans works fine?
Old January 25th, 2010, 06:58 PM   #15
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
turbo coupe rear wouln't work for you, move on & get one from a mustang. axles are a one off & so are the brakes. it will cost you 2-3x what a gt rear will in the end. sorry.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 25th, 2010, 07:16 PM   #16
neverfastenough1's Avatar
What do most guys use when doing the 5 lug conversion? I read that some guys use the longer axle from 2 Ranger rears, is that a possibility? Ranger and Explorer rears seem to be in abundance around here.
Thats exactly what people needing to do a 5 lug conversion use. Can't remember if its two left or two right ones from a Ranger, but they do it because the rangers axles are different length, and they get the two axles the same length to work with the centered chunck in a Mustang. They will work on a Foxbody, but like said not ours.
Old January 25th, 2010, 07:19 PM   #17
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
wouln't work on a turbo coupe axle either.
2012 300a GT auto
Old January 25th, 2010, 07:33 PM   #18
Nope, they get SN 95 axles and spindles. Sorry was thinking Turbo Foxbody.
Old January 25th, 2010, 08:36 PM   #19
Thanks for the info fellas. I will wait and get a rear from a 99-04.
Old January 25th, 2010, 09:08 PM   #20
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
yeah i was going to say your best bet would be to get a 8.8 out of a 99-04
Threads Similar to: Axle swap question
8.8" Axle Swap, Looking for Advice DC_Dave 2005 - 2010 V6 10 November 27th, 2009 08:03 AM
7.5" axle leftover from 8.8 swap, what should I do with it? DC_Dave 2005 - 2010 V6 2 November 21st, 2009 05:59 PM
How to: Swap axle shafts AZAlloy 2005 - 2010 4 April 17th, 2009 08:49 PM
Axle Swap LA2003 96-98 2 January 10th, 2009 09:47 PM
8.8 Rear Axle Swap Bies08 V6 Mustangs 3 May 21st, 2007 11:14 PM
