what should be my next suspension mod?
Old January 24th, 2010, 01:06 PM   #1
Cones = Yummy!
YeloPony's Avatar
YELLOW! 2001 GT VERT
46.496
YeloPony is a jewel in the roughYeloPony is a jewel in the roughYeloPony is a jewel in the rough
4.10s go in monday!.. my new sway bars and bumpsteer I'll put in after that.. so I'm trying to see what should be done next, I really want to improve my daily driving, even though I may get to AX once in a while but I'm not building a race car.
I figured MM controal arms would be a no brainer? next?
Zombie Killing Club | MM Cleavage Club #7
Specs and Pics in the garage...
Old January 24th, 2010, 01:30 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
why are you "on probation"?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 24th, 2010, 01:43 PM   #3
01KnightRiderGT's Avatar
2001 Mustang GT
01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about01KnightRiderGT has a spectacular aura about
Send a message via MSN to 01KnightRiderGT
is it lowered? you should get some LCA, and some Subframe connectors. Full lenght weld ins are the best, then some caster camber plates.
Black Stang Member #13
315's Crew Founder
My Track Videos
Old January 24th, 2010, 01:44 PM   #4
PowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nicePowerShiftz02GT is just really nice
iTrader: 13 reviews
springs/shocks/struts
Old January 24th, 2010, 01:48 PM   #5
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Did you already buy the swaybars? If not, hold off until you're done doing whatever else you're going to do. Swaybars should be the LAST thing you do, as they're there to compensate for the deficiencies of your suspension setup.
That being said, what do you mean by "improve your daily driving"? Are you looking for improved cornering or better ride quality? I'm guessing the former based on the rest of your post.
First thing I'd do is make sure the parts that you do have are top quality and in good condtion, in particular your tires, shocks, and brakes. These three will make more difference than any suspension modification.
If you have those covered and are looking to spend money, my suggestion would be full-length subframe connectors. That'll get you a good platform to build from.
If you are going to do AX, I can't stress the following enough: LEAVE THE CAR STOCK. At least until you've done a couple events and get a feel for what's actually deficient in your suspension.
Hope that helps!
O o
/¯/______________________
\_\
Old January 24th, 2010, 02:00 PM   #6
2001 Mustang GT
Hope that helps!
+1 forgot to say that.
Plus any little mod will bump you up a class
315's Crew Founder
My Track Videos
Old January 24th, 2010, 02:03 PM   #7
00redgt's Avatar
2000 mustang gt
00redgt is a jewel in the rough00redgt is a jewel in the rough00redgt is a jewel in the rough
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
and don't forget a good set of tires,all the suspension mods are useless if you can't grip the road with some tires
Old January 24th, 2010, 05:51 PM   #8
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Subframe connectors will blow your mind
Bolt on list in Garage..
Old January 25th, 2010, 10:15 AM   #9
Cones = Yummy!
YeloPony's Avatar
46.496
Thanks.. Ok
Already got Swaybars, pick them up today.. I figured FLSFC were a good bet.. As far as
"improving my daily drive & handling" .. just that, I don't drag race but I like to be able to hook up on the road, and I want better handling overall..
Rev: Thanks, I understand the 'keep it stock for AX'.. but I'm way past that point, when I bought the car is was already modded for E-Prep class. and I'm really gonna do AX for fun, I like driving my car on twisites.. Don't really car about how well I do..
So any mod that will increase my 'fun', make me more comfortable keeping speed...
Right now:
Eibach Sways
Eibach Shocks/Struts Pro Damper Kit
Steeda Springs
Steeda BumpSteer
Steeda CC Plates
*I think that's all, alot was on the car when I bought it*
New Wheels and tires will be coming soon, right now I've got Goodyear Eagles on the Front and Cooper 2XS on the rear on 17x8s.. (came with the car).. likely I'll be getting 17x9/17x10 w/ NT555s
I hadn't thought about brakes.. but yeah $$$.. I was thinking LCA or FLSFC.. I don't want to turn the car into a 'race car' really, so a $300-$400 here and there is ok..
Old January 25th, 2010, 10:23 AM   #10
Cones = Yummy!
YeloPony's Avatar
46.496
HA!!!.. I got drunk in front of the pc and posted bewbies on the forum.. I was in underground so I (my drunk mind) thought it was ok..
It's funny the punishment is no access to 'underground' and I my sig file is 'gone'.. Ask one of the mods how long it lasts.. response: no idea.
Funny!
no biggie, I wasn't trying to do anything wrong.. $hit happens...
Old January 25th, 2010, 01:27 PM   #11
zigbigadoru's Avatar
97 Mustang GT
slower than the speed of smell
zigbigadoru will become famous soon enoughzigbigadoru will become famous soon enough
just for that story your getting reps!!!!
Originally Posted by XTCNAGT View Post
That's what you get for excercising.
You think my lungs and chest hurt when I drive down the road for a triple baconator? No. You know why? Cause I'm smart.
Time for a nap.
Old January 25th, 2010, 04:28 PM   #12
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
<--Votes MM FL Subframe Connectors
Old January 26th, 2010, 10:34 AM   #13
Cones = Yummy!
YeloPony's Avatar
46.496
Lefty, who welded yours in? CJP shows $260 to install them.. I'm sure I can get that price down a bit considering the constant flow of cash I already give them.. but if you know a local guy?
I really want to do everything myself, but when it comes to welding.. sorry no dice... same with gears.. I just had them put in.. I'll take the motor apart and the suspension, but I can't weld, and anything that require me to spend more money on special tools I'll likely never use again.. it's not worth it..
Old January 26th, 2010, 11:10 AM   #14
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
They are also bolt in. So bolt em in, and take them to an exhaust shop or something. Ask em if they can weld it for ya. Since its already installed it shouldn't be too much. 240 bucks for a install is a lot i would think.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old January 26th, 2010, 11:11 AM   #15
2000 GT
If it is 260 for buying and installing, i would just go for it. But 260 for only install is a bit steep!
Old January 26th, 2010, 11:19 AM   #16
I paid more than that to have 'em installed in my fox :/
This was also on a convertible, though, so part of what I got charged was the time to work around the janky factory sfcs.
O o
\_\
Old January 26th, 2010, 11:25 AM   #17
97 Mustang GT
hahahahahahahahahahahaha are you guys high? i paid $80 to have mine welded in and the guy let me watch him/help sort of. it took like 30-45 mins tops.
edit: and it was $80 only because i tipped him like $40 for being so awesome. he only wanted like $40
Time for a nap.
Old January 26th, 2010, 12:03 PM   #18
Cones = Yummy!
YeloPony's Avatar
46.496
I have a Vert... it's 260 listed on the web site for install + cost of the SFCs(159 for powercoated MM), I'm sure I could get it a bit lower...
.. I wouldn't do a bolt on set.. I wouldn't pay $260, there are too many people in the area that could do it for less I'm sure..
Old January 26th, 2010, 12:06 PM   #19
2000 GT
They have to remove old ones. 260 for FLsubs and and putting em in is an ok price. They cost 120 for non painted, and 150 for powder coated online. Not counting shipping. So hes basically doing it for 100 bucks. Not a bad price.
Old January 27th, 2010, 11:05 AM   #20
Cones = Yummy!
YeloPony's Avatar
46.496
Just got a quote $350 (includes MM FLSFC and install)..
Threads Similar to: what should be my next suspension mod?
Black interior or suspension/brake mod vtwinjunkie 5.0 Mustangs 5 January 2nd, 2010 09:04 AM
best 1st suspension mod samstang 2005 - 2010 15 February 22nd, 2009 12:39 AM
suspension mod list BrandonJD25 General Tech 2 April 23rd, 2008 09:54 PM
:D suspension mod at least! Steve O 99-04 20 August 23rd, 2007 07:11 PM
BEST SUSPENSION MOD FOR 99 GT Jeff99gt General Tech 7 March 7th, 2007 10:42 AM
