Wiring the Gauges
Old January 26th, 2010, 01:06 AM   #1
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
Wiring the Gauges
Ok...so most of you know I hate wires. But in the sake of saving money I am putting them in myself. My Dad is very handy with with wires though.
ok. I have a Boost/Vac gauge and a Wideband o2 gauge. I likes Bakers idea on "add a fuse"
http://www.hummerxclub.com/tech/images/fuse2.jpg
But I want to wire them into the headlight switch for the dimmer function and not having the lights on all the time.
Can I still do the dimmer function with the "add a fuse" or will I just have to splice the wire in and add an inline fuse?
Thanks for the help,
Scott
Old January 26th, 2010, 01:11 AM   #2
BYAHHHH!
2001 Mustang GT
13.874
also if there an interior fuse box in the car?
Old January 26th, 2010, 01:21 AM   #3
Dancing Naked In The Rain
mcqueen's Avatar
There's a fuse box under the dash on the drivers side. There's a cover on it you need to pop off to get into the fuses.
Old January 26th, 2010, 01:22 AM   #4
BYAHHHH!
2001 Mustang GT
13.874
awesome. I thought there was but its dark and like 25 degree out...Pardon me for bing lazy on this one!
Old January 26th, 2010, 01:23 AM   #5
BYAHHHH!
2001 Mustang GT
13.874
haha I repped you to 2 green bars mcqueen.
Old January 26th, 2010, 01:28 AM   #6
mcqueen's Avatar
Woo! I'm feelin the love!
Old January 26th, 2010, 01:29 AM   #7
BYAHHHH!
2001 Mustang GT
13.874
oh dear....I am scared.
Old January 26th, 2010, 09:15 AM   #8
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
I have my boost gauge wired so that it dims with my gauges. I just took the headlight switch out and found the right wire and spliced the power wire for my gauge into that. I didn't dim the wideband because it's not overly bright, but it's almost impossible to see at night with the boost gauge lit up full blast.
For the wideband I found a wire in the fuseblock on the left side under the dash that had constant power when the key is on and spliced into that. I picked up a radioshack in line fuse holder and put that in there too.
Do the Right Thing, Cook. ~Zip.
Old January 26th, 2010, 10:42 AM   #9
BYAHHHH!
2001 Mustang GT
13.874
Thanks D.
Do you know by chance the color of the power wire of the headlight switch and the color of the fuse block wire?
Also you inline fused both gauges?
Old January 26th, 2010, 10:42 AM   #10
BYAHHHH!
2001 Mustang GT
13.874
what amp fuses?
Old January 26th, 2010, 10:56 PM   #11
BYAHHHH!
2001 Mustang GT
13.874
does anyone know by chance the dimmer wire color of the headlights switch....love not to have to go to ford!
Old January 26th, 2010, 11:03 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
Mustang tech and info links - Wiring & Vacuum Diagrams
This might help people down the road! found it searching google
Old January 26th, 2010, 11:34 PM   #13
BYAHHHH!
2001 Mustang GT
13.874
i'll just run by Ford lol
Old January 26th, 2010, 11:42 PM   #14
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
A kid I know did an install guide heres what was on his guide:
First I removed the dash gauges (remove headlight knob, remove top two screws holding plastic frame in place, then remove several screws holding the gauges in place. oh and remove the harnesses in the gauges.). After this was the most nerve racking part of my entire install; cutting a hole in my dashboard. I was using autometers dual gauge pod that mounts on top of your dash. I measure 100 million times and finally cut a 3x3 square in my dash with a dremel so that I could feed the wires to the gauges.
-The fuel pressure sensor required a special adapter (autometer part 3280) but I got it on ebay for 4 bucks.
-I fed the fuel pressure sensor harness and boost pressure vacuum line through an existing grommet in the firewall. I just sliced a small slit in it so that I could get them through.
-I t'ed into the vacuum line that is going to the driver's side fuel rail (red hose) for the boost pressure gauge.
-For the lighting for both gauges I spliced into the dark blue wire with a white stripe that is coming off of the headlight knob. This makes it so the gauges light up with the dash lights and actually dim accordingly.
-My fuel pressure gauge is electric and requires a 12v constant. for this I tapped into the wire going to fuse #1 under the steering wheel. This fuse is for the cigarette lighter.
-Once everything was hooked up and the gauges looked good I bolted the dash pod into place. Man those gauges look good. (autometer sport comp II)
And heres the whole page for it:
Procharger Install/Walkthrough/Tips and Advice - Ford Mustang Forums
Hope that helps dude.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 26th, 2010, 11:48 PM   #15
BYAHHHH!
2001 Mustang GT
13.874
Thanks you Bro!!!!! Thats what I needed! Boats n' Hoes!
Old January 26th, 2010, 11:52 PM   #16
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
No problem man. I met in on AllFordMustangs, he lives about a half hour away from. Cool kid, hes helped me with some stuff too. SHIT I can't effin wait to install my kit.
I purposley took a week off (3rd week) from work, in Febuary to do the install..lmao
Old January 26th, 2010, 11:53 PM   #17
BYAHHHH!
2001 Mustang GT
13.874
I am using the red tubes for the vacuum but besides that close to the same!
Old January 26th, 2010, 11:54 PM   #18
BYAHHHH!
2001 Mustang GT
13.874
noice! I have a guy to help me too lol
Old January 26th, 2010, 11:56 PM   #19
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Lol I have like 10 lmao.
So when he said he t'ed into the red hose on the driver's side, the gauge will pick up the Boost and Vacuum Signal right?
Old January 27th, 2010, 03:04 PM   #20
BYAHHHH!
2001 Mustang GT
13.874
yeah. I am using that red one for my BOV and Bosot gauge.
ALSO got my Bung Hole welded TODAY!!! Now is snowing for the next 3 days! and 17 for the HIGH!
Threads Similar to: Wiring the Gauges
Wiring And Lights For Gauges 04gttang Audio/Video 4 February 13th, 2009 04:39 PM
wiring gauges Blk01ponyGT 99-04 4 April 30th, 2008 02:15 AM
How to convert from a H3 bulb wiring to 893 bulb wiring? natedawgishot V6 Mustangs 0 February 2nd, 2008 12:04 AM
N/A wiring to turbo wiring 78mach1 2.3 Mustangs 2 January 22nd, 2008 08:03 PM
Wiring Gauges eastcoast50 5.0 Mustangs 2 December 18th, 2007 12:40 AM
