cam cap bolts
Old January 27th, 2010, 11:45 PM   #1
JasonT1124's Avatar
2000 Mustang 4.6l
JasonT1124 is on a distinguished road
Send a message via AIM to JasonT1124
cam cap bolts
I will be replacing my lifters, rockers and timing kit this weekend. When I was doing my cams, and then when I did my head job, I noticed that the bolts that hold the cam caps on seem to be torque-to-yield style bolts. I had a few snap on me the third time around and I am worried about re-using them a 4th time...
so my question is, can i throw some regular ace hardware bolts of the same thread/length and seat? the OE style bolts are like 5$ a piece from ford...
Old January 27th, 2010, 11:59 PM   #2
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i reused mine but this was the first time since stock... If you got some that are like it then it shouldnt be bad. I wouldnt get zink or anything soft like that.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 28th, 2010, 01:31 AM   #3
B0B
Boost gets you laid
B0B's Avatar
2001 Mustang GT
12.93@113.7 (on the 18's)
B0B is just really niceB0B is just really niceB0B is just really niceB0B is just really nice
Send a message via AIM to B0B
i wouldn't go with anything less than grade 8's if you plan on going that route. and no, they aren't tty. you are tightening them too tight!
'01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress
2003 Rubicon (wheelin rig)
2008 Silverado 4x4 (towin rig/road queen)
2009 KTM 450 XC-W (Brap Brap!)
Old January 28th, 2010, 03:02 AM   #4
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
cam cap bolts are not tty. how much torque you putting on them? they dont take much at all.
Old January 28th, 2010, 10:49 AM   #5
JasonT1124's Avatar
2000 Mustang 4.6l
I torqued them properly, I don't know how tight the guy I bought the motor from had them. One broke the first time on the way out, so I assume he over torqued them. I had another one that was completely deformed.
So looks like I'm going to the hardware store when I get them out...
Old January 28th, 2010, 01:21 PM   #6
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
Cam cap bolts only call for 90 inch pounds. That is only 7.5 foot pounds.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old January 28th, 2010, 04:32 PM   #7
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
im glad you broke that down for me! haha i set mine at 8 foot pounds because i thought thatw as about right. i looked in the manual and it said the 90-? so i kinda went in between.
If you over torque those would it cause a "clamping" on the cam making it harder for the cams to spin?
MM + Cleavage member #22
Threads Similar to: cam cap bolts
APR timing cover bolts and waterpump bolts ddarkslayer 5.0 Mustangs 3 July 14th, 2009 05:18 PM
stuck bolts and bolts that will turn but wont come out ddarkslayer 5.0 Mustangs 18 May 23rd, 2009 10:12 PM
cam phaser bolts, where to get them rakkassan34 2005 - 2010 7 March 10th, 2008 10:34 AM
Cam Bolts For PI Cams zimaad 96-98 16 November 26th, 2007 09:07 AM
