Motor clean-UP and Paint
okay i plan on getting a shortblock soo i can start my build for my boostd 2v.. my question is what compression ratio is best for a vortech wanting to push 15-16 lbs. Next question is what can i use to clean up the block like degreaser or simple green ? and can i paint it before i assemble and anything else i should kno before starting ?
Hooo Ha Ha
around 9:1 i think
id use a combo. simple green for plastics and block degreeser for metal. Super clean works good too
![]() 410rwhp 520rwtq @ 12.9 psi |
Thanks dawgy... anything i should look for before picking up a shortblock like things i should be looking out for ?
Moderator
if you are getting the shortblock just for the block and then you are going to be replacing the internals check the condition of the cylinder walls.
![]() ![]() BUILD 2 IN PROGRESS |
Threads Similar to: Motor clean-UP and Paint
| need a clean looking motor | bono | The Clubhouse | 3 | October 8th, 2008 05:16 PM |
| How much boost can you put on a stock 4.6 v8 motor with out mesing up your motor? | Jonathan | General Tech | 3 | January 2nd, 2008 09:34 PM |
| Clean your paint. (A rare serious Zip thread) | TheUNZippee! | The Clubhouse | 24 | August 4th, 2007 12:20 PM |
| How can I clean my motor | MustangMo | V6 Mustangs | 9 | May 22nd, 2007 01:07 AM |
