sway bar removal......
Old January 28th, 2010, 06:43 PM   #1
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
The sway bar people are removing is the one that has the arms that come down into the lower control arms correct? What, if any, does this really help?
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 28th, 2010, 06:58 PM   #2
Giggle Juz's Avatar
Giggle Juz will become famous soon enough
yes it helps with alittle better weight transfer to the back of car at least thats my opinon.
Old January 28th, 2010, 07:01 PM   #3
Penetration before detonation
suprajay79's Avatar
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
suprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to all
Baker, I took my front swaybar out (that is the part you are talking about here) and with a better-working driver mod, dropped an average of about .3-.4 off my e.t.
Not saying you'll see results identical to this, I mean, I was still learning how to drive her- but I do know that it helped. All my 13-second runs were with the front swaybar removed.
Beware, though, once you drive it with it off, your car will turn like a truck lol!
Originally Posted by 65eatsrice View Post
what better way to be woken up
Originally Posted by Jakashh View Post
a blowjob
Military Crew E-5/SSgt
White Mustang Crew Member #5
315s Crew Co-Founder
Old January 28th, 2010, 07:04 PM   #4
Giggle Juz's Avatar
yes it does drive like a truck also my front end floats alot and more body role to. but i dont drive it everyday.
Old January 28th, 2010, 07:09 PM   #5
suprajay79's Avatar
2001 Mustang GT
I drove it every day, but there was no way in hell I was going to out-corner a Silverado lol.
I think the weight distribution helped a ton in my launch, though- before, I would spin first, second, and third, and if I shifted into fourth, that too. It was just ridiculous.
I know that spinning in any gears other than first and maybe second is kinda futile for the argument of sway bar removal, but when I launched at the track, it hooked and booked. I didn't feel like getting under the car again, so I just left it off for a year or so, and put it back on when I came back from the desert.
a blowjob
Old January 28th, 2010, 07:11 PM   #6
Giggle Juz's Avatar
mine is still off and when i drive i forget i took it off. i agree it help my launches big time.
Old January 28th, 2010, 07:47 PM   #7
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
I haven't had mine on for years. You get used to the way it handles and will forget it's not on.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old January 28th, 2010, 07:51 PM   #8
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
well i know what im taking off tomorrow night lol.
I have been debating this forever and i now know what i must do
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old January 28th, 2010, 07:58 PM   #9
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
not only is it supposed to help the weight transfer, but that thing is HEAVY AS HELL! for being such a small peice. I had to have taken off 100 pounds off the front end this winter, that was a nice chunk of it.
MM + Cleavage member #22
Old January 28th, 2010, 08:12 PM   #10
suprajay79's Avatar
2001 Mustang GT
13.5 lbs is what 330Cube's list has the front sway bar weighing, FYI. Not a lot, but every little bit helps.
a blowjob
Old January 28th, 2010, 08:14 PM   #11
Dolbs4082's Avatar
2005 Mustang GT
removing 4 bolts and dropping over 15 pounds is pretty big, imo. but compared to the 8 bolts holding the k-member in, its not much. drop the k-member and put a tubular under it and that saves some massive weight.
Old January 28th, 2010, 08:19 PM   #12
suprajay79's Avatar
2001 Mustang GT
+1...this would be beneficial in most every realm.
a blowjob
Old January 28th, 2010, 09:17 PM   #13
Willy Mo's Avatar
Willy Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really niceWilly Mo is just really nice
yup just ordered lakewood 70/30 struts and have MMR coil over kit on the way.. so that along with mu tubular k-member and a-arms I should loose a nice chunk or weight off the front end..
I may have to take the sway bar off as well...
Old January 28th, 2010, 09:26 PM   #14
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
Hey I am not 100% on if this applies to mustangs, but if it does you should see if they make swaybar quick disconnects. That way it would take you 2 min's to remove them for the track and you can still drive home with having the stability of the swaybar
Old January 28th, 2010, 09:27 PM   #15
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Yup, my DD is a 89 F250, so my car is way better than that even without the sway bar
Old January 28th, 2010, 09:34 PM   #16
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
With anything taken off the front of the car, you can almost double what it weighs for what you really take off it since it comes off the front. Its like trying to lift a 5 gal bucket full of water straight up, it lefts easy, now lock your elbow and try and raise it with your arm at full length. Its a lot harder. same concept goes when taking weight off the front of a car
Old January 29th, 2010, 09:22 AM   #17
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
The quick disconnect is a good idea. I haven't found any kits for the mustang, but someone might be able to modify one of the kits for jeeps/offroaders to fit our stangs.
Do the Right Thing, Cook. ~Zip.
Old January 29th, 2010, 09:39 AM   #18
suprajay79's Avatar
2001 Mustang GT
That's the best analogy I've heard for this type of thing. Reps!
a blowjob
Threads Similar to: sway bar removal......
no sway bar? v8muscle 5.0 Mustangs 2 December 10th, 2009 11:09 PM
Sway bar 02v6staang V6 Mustangs 14 April 10th, 2009 04:50 PM
Rear sway bar removal 20gtvert03 99-04 10 November 3rd, 2008 06:35 PM
front sway bar removal 00gtCoolGuy 99-04 17 July 19th, 2008 04:05 PM
Sway Bar scxc15 V6 Mustangs 14 October 12th, 2007 09:06 AM
