valve seals/spring
Can the valve springs be changed without holding the valve up with compressed air? What about the seals?
Vortech V2 Si
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Yes youll just have to bring the cylinder youre working on up to tdc or close to tdc so the valve cannot fall. This method is actually safter than using compressed air.
99 limited edition vert
I use both, piston on tdc and air. after you try putting keepers on, you will see why it is way easier with air holding valve up
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
that is indeed a p a i n in the a s s
02 Mustang GT
9.91@133
Be sure to cover the oil return holes. It is easy to drop the keepers and they will fall right through those holes.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
Threads Similar to: valve seals/spring
| Valve spring compressor | ModularSteed | 96-98 | 5 | June 19th, 2009 01:20 AM |
| Valve Spring Kit?? | BoostHard1210 | 99-04 | 11 | February 12th, 2009 09:19 AM |
| valve spring upgrade? | V6Power | 99-04 | 3 | December 7th, 2008 04:11 PM |
| Valve Spring Troublee! | tehdwarvenn | 5.0 Mustangs | 12 | September 12th, 2008 07:20 AM |
