#21 | |
2003 Mustang GT
14.03@100
#22 | |
So the ones I have are okay?
Vortech V2 Si
#23 |
2003 Mustang GT
14.03@100
You're on stock internals at that level? I wouldn't even do cams then until a built bottom end.
#24 |
I'm going to lower the boost some to compensate.. that was at 14psi.
Vortech V2 Si
#25 |
02 Mustang GT
9.91@133
He has no need for ported heads with stock rods & pistons. Guys have made 600rwhp with stock unported heads. If he had ported heads it would just take less boost to make same power to which he is limited to around 430rw.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
#26 | |
Installed Height - Coil Bind - .060” = Maximum Recommended Valve Lift This formula is a general guideline for calculating maximum valve lift with a safety margin of .060”. Other factors such as rpm will also affect valve spring selection, however this is a good formula to use in most performance applications. Jim at CMS said that these springs were okay to use with N/a vt stage 2 cams with 560"/.575" lift Do you think I'll still be okay with a lower safety margin?
Vortech V2 Si
#27 |
99 limited edition vert
I personally don't like to exceed manufactures guidelines, they are there for a reason and not a number pulled out of a hat. .060 safety margin has some r&d behind it.
In the end it is your call. If your concerned, just run some offset retainers, they will give you another .060 and you won't lose to much seat pressure because I believe the beehives have a heathy one anyway
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#28 |
2000 GT
Maybe, maybe not. Question is do you want to risk doing this twice
And having to buy new springs and not be able to sell or return your current ones that are still in box.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#29 |
If these cams are new, return them for 2.5's..problem solved
#30 |
If the motor was stock,it wasn't because of the cams
#31 | |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Or the CMS stage3 blower cams! haha
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
#33 |
02 Mustang GT
9.91@133
The comp high load springs have a max lift of .650 leaving only .020 till coil bind.
The nextek springs max lift of .580 only leaves .020 till coil bind also. I just called comp themselves and they said your springs will be fine with the .047 clearance. If you are really worried. You could buy just 8 high load springs for the exhaust side here. http://www.compperformancegroupstore...Category_Code=
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg Last edited by y2k02; January 29th, 2010 at 02:41 PM. |
Threads Similar to: Will beehive springs work with vt stage 2 blower cams?
| vt stage 2 blower cams | mystang0673 | 99-04 | 3 | January 27th, 2010 12:06 PM |
| Stage 3 heads/blower cams? | jivepepper | 99-04 | 4 | April 29th, 2008 02:25 PM |
| stage 3 blower cams | lilmarc1988 | 99-04 | 42 | April 16th, 2008 10:27 PM |
