Will beehive springs work with vt stage 2 blower cams?
The springs that I got with my cams say max lift .550 but on the exhaust side of the cam the lift is .571. Are the beehive not good enough even if I keep the rpm down?
Vortech V2 Si
#2 | |
2003 Mustang GT
14.03@100
Patriot Performance 4.6L 2V Valve Spring Kit (99-04 GT) at AmericanMuscle.com - Free Shipping! |
they will work but you probably need 600 lift springs to make sure you have all the seat pressure you can get so you wont loose any power at any rpm..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
#4 | |
Vortech V2 Si
I was planning on doing this today so it sucks if these springs won't work.
Vortech V2 Si
2003 Mustang GT
14.03@100
Why would you put VT stage 2 blower cams in stock heads to begin with?
more power?
Vortech V2 Si
2003 Mustang GT
14.03@100
Ya but you'd definitely want ported heads for those to REALLY scream. Just my .02
Yeah but then I'd break my engine so I'm just doing the cams for now.
Vortech V2 Si
02 Mustang GT
9.91@133
What springs did you get?
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
2003 Mustang GT
14.03@100
How would you break your engine? You probably also shouldn't do them now at that lift just because of PTV clearance issues. You'll definitely wanna notch the pistons.
Comp Cams 26113-16
Comp Cams Valve Springs Kit Beehive (96-04 4.6L 2V) I don't know exactly how it would break, maybe throwing a rod? I thought none of the vt cams had any ptv issues.
Vortech V2 Si
02 Mustang GT
9.91@133
The lift doesn't cause ptv.
2000 GT
And no VT's dont have ptv issues. Been running mine for 2 years with "stock" heads, just have the springs and stainless steel valves when they were inspected. (so wish it was ported, i thought i asked them to get it done!)
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2003 Mustang GT
14.03@100
I wouldn't say "No VT's have PTV issues" Cuz aa buddy of mine had PTV issues w/ his VT cams...
2003 Mustang GT
14.03@100
How in the hell would you throw a rod by porting your cylinder heads???
Which springs did you use?
Vortech V2 Si
They can only handle so much force before they break.
Vortech V2 Si
2003 Mustang GT
14.03@100
What is your power output? Ported heads are NOT going to hurt your engine.
02 Mustang GT
9.91@133
installed hight 1.57
coil bind .952 That leaves .618 lift before bind your cams .571 lift Leaves .047 clearance I don't know why they rate them for .550 lift.
Threads Similar to: Will beehive springs work with vt stage 2 blower cams?
| vt stage 2 blower cams | mystang0673 | 99-04 | 3 | January 27th, 2010 12:06 PM |
| Stage 3 heads/blower cams? | jivepepper | 99-04 | 4 | April 29th, 2008 02:25 PM |
| stage 3 blower cams | lilmarc1988 | 99-04 | 42 | April 16th, 2008 10:27 PM |
