theft light flashes, car will not turn over - Page 2
Old February 2nd, 2010, 10:40 AM   #21
JasonT1124's Avatar
2000 Mustang 4.6l
JasonT1124 is on a distinguished road
Send a message via AIM to JasonT1124
The pats system is a fuel cut off. The car will still crank if the improper key is being used, it will just not fire up. The problem with the dashed lines indicates a problem with your computer. If your dealer loaded a "blank" or corrupted tune then you will get the problem with the dashed lines.
Plug in your programmer and see if it can communicate with your ecu... if not, they loaded a blank tune or the main fuse may be blown to your ecu (its a large, large green 30 amp fuse in the underhood fuse compartment)
I am leaning more toward a problem with the tune than a problem with pats in general...
Old February 2nd, 2010, 10:41 AM   #22
JasonT1124's Avatar
2000 Mustang 4.6l
also- if pats were causing this problem you would still see the mileage on the cluster, not dashed lines.
Old February 2nd, 2010, 11:01 AM   #23
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
I agree with baker... hes trying to steal that car! Though by whats listed i would too...
check your fuses. Try and retune the car yourself if you can
410rwhp 520rwtq @ 12.9 psi
Old February 2nd, 2010, 01:32 PM   #24
330CubeGt's Avatar
1997 SVT COBRA
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old February 2nd, 2010, 02:51 PM   #25
BAHbA is on a distinguished road
guys thanks for all your help, i am going to work on it this afternoon, i should have more info later on....talk to you soon...
Old February 2nd, 2010, 03:07 PM   #26
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
I had a similar problem with my 03. I, like a idiot, erased my ECU while messing with my SCT2. Then ford replaced it free of charge. Of course i didnt say i was messing with my SCT2 and erased it.
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx 92gt short block w/gt40p, explorer intake, 65mm tb, 373 gears, 76mm C&L maf, tubular K-member 14.15 @ 94 (5000' above sea lvl)
Old February 2nd, 2010, 06:20 PM   #27
JasonT1124's Avatar
2000 Mustang 4.6l
Originally Posted by 330CubeGt View Post
yes it will. my car cranked like a champ when i had a 2$ home depot key copy and an ecu out of the junkyard before i got pats shut off.
Ive also had both a corrupt and a blank tune loaded in my car.... both times it cranks just doesnt fire
I think that I was a little unclear in my earlier post. The car will crank if you are using the correct key for the car, but do not have the correct ecu, or original tune.
PATS not only communicates with the ecu, but also a seperate module behind the dash (sometimes in near steering column, sometimes in the cluster, depends on the ford). If both the ecu and the module read incorrect I believe it will not crank... but i promise you it does when you have changed only the ecu
Old February 2nd, 2010, 07:49 PM   #28
it's fixed, i traced the wires and found a broken wire, engine bay, passenger side in the harness...i think it was damaged for a while, now that i installed the intercooler piping and moved it around it finally broke...
thanks for all your help guys....
Old December 21st, 2010, 01:09 AM   #29
izo
2001 Mustang Gt
izo is on a distinguished road
hi,
I have a similar problem with my 2001 Mustang Gt stick. The theft light blinks and odometer shows -----. I took the car to Chapman's ford in Philadelphia today, they tried to connect to the ecu but they couldnt. The problem is i have to fly tomorrow overseas and I want to learn what the problem is. Actually I am new to Philadelphia and I would appreciate if any of you guys give me a contact or address for a service which can fix this type of problem besides the dealers. thank you..
Old December 21st, 2010, 03:21 AM   #30
ndfrspd's Avatar
1998 Mustang GT
1:34.43@13.86
ndfrspd is infamous around these parts
Originally Posted by dcook_14 View Post
I'm having the same kind of problem. If I turn the key just to on, all my electronics fire up (lights come on, radio plays) but as soon as I turn it to start, all the power is cut. If I go out and move the battery cables, all the stuff turns back on, but when I turn the key to start, it cuts power again. WTF?
Bad ground. I was having same problems, its either cause ur battery is below cranking voltage or cant seem to hold a charge above cranking voltage, or you just have a bad ground. one of the grounds to check is running from your front driverside wheel up to the driverside motor mount area, its a flat copper braided wire that should be connected from the block to the chassis. it makes perfect sense because your starter is grounded and if the ground is bad, well hey, you got no starter ha!
"The only way to learn about a car truly is to break something and fix it yourself..."
Threads Similar to: theft light flashes, car will not turn over
Theft light Rico-mofos 2005 - 2010 14 January 29th, 2009 10:33 PM
Car wont start Theft light on **HELP** PapaSmurf 99-04 4 September 27th, 2008 09:28 PM
why is my theft light going nuts greenstang97 V6 Mustangs 9 March 16th, 2008 02:32 PM
Theft Light comes on, but dont have an alarm on the car WTF Mooooose 96-98 6 May 13th, 2007 06:23 PM
theft light comes on 4point6GT 96-98 4 October 14th, 2006 11:17 PM
