Manifold Choice
Old February 4th, 2010, 07:54 PM   #1
Stang25 is on a distinguished road
Manifold Choice
Soo I my mechanic said that ive have a bad manifold gasket that needs to be changed because im loosing my coolant. since im doing the fix myself and im gonna be taking the manifold off anyways I was debating on just changing the manifold itself too. anyone suggest a different manifold because im getting mixed opinions saying that after market ones arent worth the money. just curious
00GT-SLP LM2's, Pypes x-pipe, BBK CAI, MGW short throw shifter, Centerforce DF Clutch, KYB Shocks and Struts..coming soon SCT XCAL3, 70mm throttle body, and Plenum
Old February 4th, 2010, 08:04 PM   #2
2001 Mustang GT
TheHambone will become famous soon enough
Depends.. what are your long term plans? Boost? Spray? High rpm?
I love my Edelbrock..
Old February 4th, 2010, 09:20 PM   #3
V6 Pony Car is on a distinguished road
Is that SOCH or DOHC Manifold? I can't find a listing for a DOHC intake on Edelbrock.
Old February 4th, 2010, 09:21 PM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
If i were you I would just keep the stocker and save the money. The stock intake is a very good design and works great
Old February 4th, 2010, 09:21 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
You have a DOHC?
Old February 4th, 2010, 09:22 PM   #6
Penetration before detonation
suprajay79's Avatar
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
suprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to allsuprajay79 is a name known to all
That's the SOHC manifold.
96-current GTs have SOHC engines from the factory.
Originally Posted by 65eatsrice View Post
what better way to be woken up
Originally Posted by Jakashh View Post
a blowjob
Military Crew E-5/SSgt
White Mustang Crew Member #5
315s Crew Co-Founder
Old February 4th, 2010, 09:34 PM   #7
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Agreed. But if you have plans of going with Nitrous, or supercharger in the future, you could upgrade. Could just do it to give the engine bay a half way decent look.
Professional Products has the Typhoon Intake...Looks good, I dont think it has any real gains. The Foxlake P-51 Intake is badass. The Trickflow Intake is sick. Just some ideas. The cheapest is the Typhoon Intake though.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 4th, 2010, 09:48 PM   #8
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Your right, it actually takes power away. It flows like crap and also being cast aluminum which is pretty thick, gets heat soaked and stays hot for a long time, hurting performance
Old February 4th, 2010, 09:55 PM   #9
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Yup, I forgot to add that. So if your into loosing power for looks, go with the Typhoon intake..lmao.
But unless your going nitrous, or supercharger it'll help you in the long run. Thier "supposed" to make like 25rwhp at like 6500rpm. But Our motors dont spin that high. So me personally, I wouldnt get it.
Old February 4th, 2010, 10:21 PM   #10
2001 Mustang GT
The typhoon is cheap, and so it the Edelbrock..
Intake 289.99
Rails 99.99
FRPS adapter fittings $30
Fittings and hoses $50ish
The Edelbrock makes insane improvements over stock when boosted or high RPMs. With my turbo cams I turn my motor to 7400, so I see nice benefits from it up top.
Old February 4th, 2010, 10:29 PM   #11
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
You forgot about the adapter plate for stock style plenum or custom upper.
How much hp at 7400 does your car make? Do you have a graph you could post??
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old February 4th, 2010, 10:45 PM   #12
2001 Mustang GT
I just made my adapter plate out of a sheet of steel plate I had here. Plasma and magic marker work wonders. Only thing I bout was a carb flange gasket. I had the tap and bolts and such already here. Will have new dyno sheet with turbo instead of blower next week. Ill post that then. I dont have a sheet from my dynos with the blower. We wont discuss my numbers, kinda embarassed. I have a fully built car, with a baby v2 sq si, over spinning it by 10,000rpm. 600hp range isnt going to cut it for me.. I should be making 800hp range next week.
Old February 4th, 2010, 10:48 PM   #13
koessl's Avatar
1998 GT suckaaa
4 tickets @ 1 stop
koessl will become famous soon enoughkoessl will become famous soon enough
id never heard of the Foxlake P-51 intake... just checked it out. thats in..cred...ible. oh my god.
Military Crew
Completely stock... I promise.
Old February 4th, 2010, 11:13 PM   #14
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Is the elderbrock intake a good bang for the buck part? Could i do it instead of a Pi intake swap?
410rwhp 520rwtq @ 12.9 psi
Old February 4th, 2010, 11:18 PM   #15
2001 Mustang GT
Hell yes its a nice piece... much better than the plastic tank
Old February 4th, 2010, 11:19 PM   #16
You have a DOHC?
Yes, it is a fresh built DOHC with a Teksid block and the stock Cobra intake. The intake is that good?
I'm new to the MOD motor so I'm learning as I go, and the curve is steep. A lot of variations in 19 years.
Old February 4th, 2010, 11:33 PM   #17
2001 Mustang GT
Well I guess get a Sullivan then
Old February 5th, 2010, 07:03 AM   #18
y2k02's Avatar
02 Mustang GT
9.91@133
you're imbarassed about your numbers, but say you made nice gains.
Also most people cant make there own plate.
The edelbrock is not for a stock shortblock engine.
OP should just get another PI intake. My car over 600rw with stock pi.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old February 5th, 2010, 08:45 AM   #19
KhaosGT's Avatar
KhaosGT is on a distinguished road
I have the same problem, I'm thinking thirty dollar gaskets instead of a new intake
2004 Black Mustang Gt
When I see a 5.0...I respect my elders.
Old February 5th, 2010, 09:06 AM   #20
thanks guys, yeaaa i think im just heading towards replacing the gasket for now..might be uprgrading to newer stang anyways
Threads Similar to: Manifold Choice
Swapping a 98 V6 intake manifold with for a 99 V6 manifold 98mustang V6 Mustangs 6 November 20th, 2010 11:20 PM
next choice Codeman V6 Mustangs 5 May 13th, 2009 08:48 PM
Your choice 351cleveland_:D 2005 - 2010 22 April 17th, 2009 11:23 AM
if you had the choice... B0B The Clubhouse 30 April 15th, 2008 07:00 AM
No name single plane manifold VS Victor Jr manifold hitorx 5.0 Mustangs 5 May 11th, 2007 08:47 AM
