Big timin' in a small town
!!!!Bleeding BRAKES HELLLLP!!!!
Im trying to bleed my brakes and I bled them to the procedures in the instructions. RR, RF, LR, LF And they still are shitty
I had to bleed the front two by the lines since the bleeders are corroded to the damn caliper. But why would that make a difference? Ive done that tons of times while bleeding and never had an issue doing it through the lines. I then bled the top two bleeders on the master cylinder and nothing. It will pump up if you pump the hell out of it but as soon as you quit pumping and wait a few second and hit it again it will go right back to the floor. My dad tried to get the bleeder open and snapped one off so now hes gotta fix it tomorrow at work. So Im kinda fucked right now anyway. Im so close to just saying fuck it and buying Cobra calipers
48.47@ 12.58
Hooo Ha Ha
+1 on cobra calipers. Is she low on brake fluid? idk just a guess
![]() 410rwhp 520rwtq @ 12.9 psi |
!FACEPLATED!
Bleeding is RR, LR, RF LF. You start the farthest from the master and work your way to it.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#5 | |
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
also, are you getting good ammounts of fluid out? If not, you may have degraded flexible brake lines. Cobra calipers are FTW as well. Make sure you get the cobra brake lines or you will have a when they don't bolt up.
#6 | |
4V swapped '02 GT
(2v) 13.9@101
![]() ![]() ![]() ![]() iTrader: 10 reviews
&&just do the cobra calipers/rotors. you wont be sorry ![]() but...i dont understand whats different about the lines ? when i did my swap all i got was calipers and rotors. nothing more. i unthreaded the fitting that goes directly into the GT caliper and it re-threaded right onto the Cobra calipers.
![]() BSD 100MPH Club YMR #8975 4v Swap and a little Purple Bottle ![]() MM Nitrous Club #7 MM Cobra Club #87 |
That.
Yeah, Cobra brakes. You'll still have to bleed them. Get new bleeders and go from there. Bleed all the brakes like said and then the master cylinder. I always get more air out of the master cylinder.
1999 Mustang GT
13.8@100
are there any good step by step manuals for bleeding the master cylinder? i keep hearing about having to "bench bleed" the master cylinder if it comes down to actually having to do it. Is this correct or does bleeding it by the 2 bleeder screws on the bottom like a few people have said work?? please let me know if anyone can give me some tips, ill be doing this in a few weeks.
The Big Spoon
never fast enough
yes, you will have to bench bleed it first in a vise. Make sure that any shipping goo has been cleaned from the piston area there the pushrod goes in. (I had an issue with a stickey shipping substance being in there and not letting the piston return all the way to home base. Until I got that piston issue resolved, it wouldnt properly bleed)
If you dont have a vise, you can bolt it into the car and have a buddy help you out by pumping the brakes while you hold the tubes in the reservoir. The help aisle at the auto part store may sell a bleeding help kit with some clips on it that would let you do it by yourself. You would have to rig a mirror up so you can see when it is properly bled (no bubbles) when you're pumping. |
1999 Mustang GT
13.8@100
Hey guys, sorry to resurect this again but, I am about to bleed my brakes soon to put on my Roush/Alcon big brake kit. I just want to make sure I got some of the sequences right. From what I have heard I thought bleeding the master cylinder (by the 2 bleed screws) and then the RR, LR, RF, LF was correct? Should I follow this way or bleed them like advised above where one should bleed all the wheels first and then the master cylinder? Let me know what is the best way to go about doing this.
Also, Ive never bled the master cylinder by the bleed screws. Is it the same process as the wheels? (pump up to get pressure, press and hold pedal while one of the bleeder screws is opened, then close the screw before letting pedal go, and repeat). And which screw should be bled first? The one closest to the firewall or the one closest to the battery, or can they be bled at the same time? Please let me know any info, and thanks in advance!
#12 | |
04 gt dsg
#13 | |
The Mean Green
1996 MUSTANG GT
Don't y'all use clamps? ...Gotta clamp off those hoses, keeps the air out....Snap on has a cool set (at least that's where I got mine...don't know who else carries them...)
Next time Sug, use clamps.
“I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day.” ~Frank Sinatra
1996 MUSTANG GT
Oh HELL! and have ya checked your lines? any leaks? and how does the seals look on your calipers and MC?
How much fluid have ya "lost"?
2003 Mustang GT
13.2@99mph w/slicks notch 14.1@ 97mph
What kind of brake fluid are you using? should be using DOT 3. Make sure its not contaminated with water.
Threads Similar to: !!!!Bleeding BRAKES HELLLLP!!!!
| Bleeding rear drum brakes | chrisbmx | 5.0 Mustangs | 7 | November 5th, 2009 07:12 PM |
| bleeding brakes | chrisbmx | 5.0 Mustangs | 7 | October 31st, 2009 05:17 AM |
| Gravity Bleeding Brakes? | chrisbmx | 5.0 Mustangs | 4 | October 31st, 2009 02:38 AM |
| Help bleeding brakes | powershifter | 99-04 | 5 | July 18th, 2009 06:34 PM |
| bleeding brakes question | supercharged03gt | 99-04 | 3 | September 14th, 2008 12:04 AM |
