12's n/a stock gears? - Page 2
Old February 17th, 2010, 07:08 PM   #21
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Originally Posted by saxmanJJ View Post
There's a guy that runs at Atco Raceway that runs an 2004 in the high 12s on a good day who's got a stock longblock with all the boltons. I think he's got 4.10s though, with a stick shift. He runs Hoosier DOT race tires on Welds with skinnies in the front. I think the stock 3.27 gear is going to keep you out of the 12s. I think 4.10s are almost a necessity with nothing but bolt-ons.
Thats what I do, I ran 12.8s flat
Old February 17th, 2010, 07:13 PM   #22
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
doubt it can be done, this coming from the guy that tried to do everything for the first time. but really what is the point, why not just put gears in it and lightin it up. i mean its like wow if you run a 12.99 with stock gears, i will just show up with the same amount of power, with 4.56's and same weight and run 12.50's. I don't consider running anything with stock gearing bragging rights. Who wants to drive around on stock gearing anyways.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old February 17th, 2010, 07:14 PM   #23
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Tim, you know you are my idol, lol. And my goal was to get my car to look like yours
Old February 17th, 2010, 07:15 PM   #24
Moderator
Gears=win
Old February 17th, 2010, 07:37 PM   #25
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light330CubeGt is a glorious beacon of light
iTrader: 14 reviews
Its time to move on, It seems you have reached a stopping point with the current setup, Hell even go back with the shorter triple 5s out back if itmakes you happy and see if you get anything better but i doubt yo will see 12s.
Either bite the bullet and go with 4.10s and Dip into the 12s or Start removing weight there really your only two Easy options, And stop worrying about what other people say the car can or can not do and just have fun with the car
-04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI-
Old February 17th, 2010, 07:43 PM   #26
Blackbird1084 will become famous soon enough
To prove local gm guys and ford haters wrong. My goal was to just hit a 12.99 with stock gears,full weight and right after take the seats,Jack,spare and anything else out to see what the diffrence is. Then throw gears in it and see how far in the 12's n/a and 11's on spray I could get before a set of cams. Basicly to prove a couple of loud mouths wrong.
79 Buick regal 13.70 @102 350 sbc
97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir
04 SRT-4 13.42@113.55 2.37 60ft
04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot
06 Mustang GT 12.2929@114.30 2.01 60ft
MM Bracket Racing Crew Member #4
Old February 17th, 2010, 09:02 PM   #27
330CubeGt's Avatar
1994 Mustang 5.0
1996 Mustang V6
iTrader: 14 reviews
Put 4.10s in the bitch and keep quite its that easy, they will think its stock.And there not going to shut up there going to fine something else to say, Its all part of the game.
Then put it on a Diet...
Actual numbers are from Either from 330CubeGt or 96SOHC
Drivers seat Leather 48 lbs
Passenger seat Leather38lbs
Rear seat Leather top half 30lbs
Bottom Rear seat 15lbs
Sounds deadening (Removed w/Torch and Scraper) 45-50 Lbs
Door Panels 8Lbs Each
Extra metal out of front bumper (Center) 8Lbs (Kept most of it)
Front Sway Bar w/links 13.5Lbs
20Lbs going to front coild over setup.
20 Lbs going to lighter front seats with manual sliders.
CD Player Head Unit 5 Lbs
Rear End Dog bone 10 lbs
metal plate under steering column 3.5 Lbs
Wind shield washer tank 1.5Lbs Empty/8Lbs Full
Passenger side air bag 9Lbs
Drivers side air bag 3 Lbs
Air bag sensors and module 3Lbs
Hood latch w/cable etc 2-3Lbs
Cruise control (In Fender) w/cable 2-3Lbs
Glove Box 4lbs
Trunk Lining with spare tire cover 14Lbs
Spare tire 25 lbs
Jack and tire iron 8lbs
Smaller battery 10Lbs
Mach 460 Amp Rack 6Lbs
Mach 460 Speakers 2.25 Each
6 disk changer 2Lbs
Rear Seat belts 5 Lbs
Sun Visors with harness 2.5 Lbs
E-Brake Assembly w/cable 7.5 Lbs
Black boxes behind rear tires w/brackets 3Lbs
rille insert and Radiator cover 2 lbs.
Mott bar and bumpstop bracket 9 lbs.
Fog Lights and brackets 6 lbs.
Rear Bumper support brackets 6 lbs
Factory Spoiler 9 Lbs
Strut tower brace 8 lbs
Complete Front Bumper support 17 Lbs
Quad Shocks w/brackets 8Lbs
Rear Sway Bar 8.5Lbs
Convertible K-Member brace 17Lbs
Firewall blanket 15 lbs
Door Bars 8 lbs
Dead pedal 1 lb
Tailpipes 20 lbs
Evap Canister 5 Lbs
EGR and DPee 4 Lbs
Rear Bumper 25 Lbs
Convertible top pump/motor/cylinders 12 lbs
A/C Complete 30 Lbs
ABS Pump Delete 14 Lbs
99-04 Brake Calipers 10 Lbs Vs. 14 Lbs 94-98 style
wiper motor and linkage 6 lbs
Heater core/A/C box/ fan 19 lbs
Bumper suppor mounts w/wind deflectors 5.5 Lbs
Stock A-Arms 30 Lbs, Tubular A-Arms 15 Lbs
hydro-boost and master cylinder assembly 17lbs
Power steering pump 10 Lbs, Delete pulley 1.2 lbs
Power steering lines and Res 5.5 Lbs
lock mechanism,window motor,wiring harness 12 lbs
Gut underside of Trunk, Trunk will weight 20-25Lbs
Few Lbs Misc Nuts/Bolts and Removed Metal.
Get to Work!!!
Old February 20th, 2010, 03:55 PM   #28
8URSRT's Avatar
1989 Coupe
11.49@124
8URSRT is on a distinguished road
102 MPH is plenty to run 12.90's. He'll probably get a counple tenths from headers and then another couple from a much more capable tire.
IMO its VERY possible.
Old February 20th, 2010, 04:01 PM   #29
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Speaking from experience and trying it, its not possible with stock gearing. The car cant get rolling quick enough
Old February 20th, 2010, 05:09 PM   #30
MATT02GT's Avatar
MATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the rough
God I hate altitude.... I barely hit 12's with boost
Bolt on list in Garage..
Old February 20th, 2010, 05:15 PM   #31
Shaun03GT's Avatar
2003 Mustang GT
1/8 - 8.09 @ 91.39mph 1/4 - 12.35 @ 114.52mph
Shaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud of
iTrader: 11 reviews
I know some guy on Allfordmustangs. Has an 01 Bullitt, 259rwhp. His best run stock gears was 13.26 @ 102.7. So, I think its very possible with suspension, tires, Longtubes, mid pipe, TB/Plenum, intake and a 1.7 60 foot.
2003 Mustang GT Vortech V1 Intercooled
SAE Corrected - 380rwhp & 380rwtq @ 9psi
Uncorrected - 401rwhp & 400rwtq @ 9psi
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 20th, 2010, 05:24 PM   #32
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
Can't see it happening without gears man.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old February 20th, 2010, 09:04 PM   #33
2003 Redfire Mustang GT
before new mods - 13.60@101.40
OH03GT will become famous soon enough
i dont know man, im kinda doubting 12.99 full weight and stock gears. bolt ons will help, n what Shaun03GT said u might get close. but itll be hard to do since stock gears are kinda slow
MY GARAGE
MM Bracket Racing Crew Member #2
Originally Posted by Scott2001GT View Post
mmmmm went from wanting to see a chicks picture to dick measuring...MM.com
Old February 20th, 2010, 09:41 PM   #34
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
I don't understand why you would want to try to run 12s on the stock 3.27 gear. Just go with some 4.10s and be done.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old February 20th, 2010, 09:44 PM   #35
Originally Posted by Blackbird1084 View Post
I've been told by a few locals it can't be done but I want to try and prove them wrong.
MY GARAGE
Old February 20th, 2010, 10:16 PM   #36
tomkat69247's Avatar
2001 Mustang GT
tomkat69247 is on a distinguished road
dnt the bullits have 3.73's?
Old February 20th, 2010, 10:24 PM   #37
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 11 reviews
They dont have 3.73's, but now come to think of it they MAY have 3.55's.
Old February 21st, 2010, 12:04 AM   #38
Well if it'd stop flipping raining here I'd have a chance to try but all it's freakin done here is snow and rain. And I think it can be done but it's deffinitly gonna be hard. And I've already posted that it will get gears somtime this year just not yet.
Old February 21st, 2010, 12:47 AM   #39
mpe331lx's Avatar
9.74@142
mpe331lx will become famous soon enough
I'm not going to say its impossible. But it is VERY unlikely to happen at full weight with 3.27s.
The 4.6 cars are undergeared from the factory. They need a steep gear to get them out of the hole hard and to get them into thier power range quickly.
Old February 21st, 2010, 12:58 AM   #40
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
Been thinking on this one for a while. Way back in 2002 I ran a 13.45@102 at Beech Bend Ky. on a very nice 50* day. Also ran a 13.55 and a 13.59 same day. The ONLY mods at the time were, K&N drop in filter w/no silencer, MAC O/R X with welded in Flowmaster 40's and a UPR shifter. Stock tune, spare in the trunk,full interior etc.
So I see it is possible with a few bolt-ons, some suspension work and sticky tires.
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Threads Similar to: 12's n/a stock gears?
stock gears JStang14 96-98 18 January 25th, 2008 02:28 AM
stock gears mustangrebuilder 2005 - 2010 7 January 10th, 2008 11:51 PM
8.8 Stock Gears scxc15 General Tech 1 December 13th, 2007 11:00 PM
stock gears dr.gonzo! 99-04 1 April 24th, 2007 01:25 PM
