My FMIC Setup
Old February 18th, 2010, 02:28 PM   #1
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
My FMIC Setup
Okay, so I took the hood latch support out and gave me all the room I needed. Heres what I have:
Would be coming off of the V1 Head Unit:
Held up by the jackstand for the time being. Mounts onto the radiator support:
Going up to the fenderwell
Then the pain in the ass, making this part work and fit togeather right:
Just trying to get it to fit right into the throttle body. I also have the PMAS blow through MAF...Do I need to cut a hole by the fender well to make the piping fit and the air filter?
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 18th, 2010, 05:56 PM   #2
40thAnnivGT's Avatar
12.35 @ 116
40thAnnivGT will become famous soon enough
Only thing I can think of is cut the piping from the throttle body so you can fit you MAF.. :
Old February 18th, 2010, 05:58 PM   #3
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i had to cut the hole larger for my afm powerpipe and piping to go through. With kits like that, cutting may be necessary. You just want the piping to be straight for about 6" before going into the maf.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old February 18th, 2010, 06:08 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Yea, Im cutting a larger hole where the fenderwell is. Hoping I can make it fit right. Looks like a pain in the ass, the 2nd pipe coming off the throttle body on the last picture.
Ill do the best I can, I scheduled a dyno tune for saturday so Im getting most of this out of the way tonight, and tomorrow should be the oil pan tap, bracket assembly and finishing it. Idc if Im up til 3am tomorrow night, Ill have it done by 9am for my dyno tune lol.
Old February 18th, 2010, 11:20 PM   #5
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Jesus these Vortech instructions are garbage. They suck they give the worst directions ever. Its gettin me aggrivated because they dont explain anything thouroughly. This is whats going to hold me up, plus theres some stupid shit I have to do to. I need to file where the idler pulleys go. Have to bend an AC line. I need to cut a hole where my fenderwell is, but I cant cut where I wanted to because theres a plastic box it looks like where I needed to. F*CK! I really really wanted to bring it in Saturday morning to have it tuned. Cause hes not opened on Sundays and I have to work effin Monday morning 6-2:30, and through the rest of the week. Gay
Sorry, I needed to vent real quick.
Old February 18th, 2010, 11:24 PM   #6
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
When i put my S/C in I had to work the next day and I needed the car to go to work. I know where your coming from man.
410rwhp 520rwtq @ 12.9 psi
Old February 18th, 2010, 11:32 PM   #7
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Yea its just aggrivating. The bracket assembly is stupid....Accually its not bad, but the instructions get me fuckin heated because it doesnt show or explain anything.
Plus I couldnt find the feeler gauge to measure the spark plugs, so that fuckin held me up.
So tomorrow this is what has to get done, longshot? yes:
Go to Sears and get the fieler gauge and 3/8 NPT tap.
Spark plugs gapped and put on
Top of the motor all put back, throttle body and vacuum lines
Measure the intercooler and get it dead center with the radiator support
Drill holes into the radiator support and mount the intercooler
Mount the head unit on the the bracket, and pulleys
File the areas were the pulleys go, and bend the AC line
Drain the antifreeze and cut the coolant hose
set the piping up for the intercooler
Clock the head unit the right way
Mount the mounting bracket
Oil pan tap and connect everything to the bracket, and throw the belt on
And I think thats it. Can I get that all done from about 3pm til about 3am? Me and my dad....I fuckin hope so.
Old February 18th, 2010, 11:48 PM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
iTrader: 10 reviews
For the coolant hose. Just drain it till the resivoiur is drained. Then go a little more. Then clamp the hose with some clamp (sears has them if you dont).
Youll get it done. Dont worry. Just stay focused and youll have it.
I could probobly pull that off with my buddy in 12 hours so you can to.
Id go to sears first thing tommarow. Then buckle down for the night. Take care of the oil pan first. Its the part you didnt want to do. So start on it early so you dont feel rushed later in the night and your starting fresh.
Old February 18th, 2010, 11:50 PM   #9
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Yea true.
I definatley gotta finish the top of the motor just to get it out of the way. Just gap the plugs and put the TB back on and done. That should take a half hour.
Then do the oil pan, and start plugging away. I hope I can get it all done tomorrow.
Old February 18th, 2010, 11:54 PM   #10
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
+1 to shark. Start on the hardest part first, so when you are tired later and pissed off you don't break things :p
Half that stuff if CAKE, don't sweat it. Putting in plugs takes what 3 mins? I personally think setting up the piping will be the biggest pain. And tapping the oil pan is second.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old February 18th, 2010, 11:56 PM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Definatley agreed. I think the instructions get me more stressed than anything. They dont explain anything. There garbage. Thats whats pissing me off the most. I have the intercooler pretty much lined up, just the last 2 pipes going to the throttle body have a wierd fitment....I think I can get it to work though.
Threads Similar to: My FMIC Setup
CX racing FMIC? 05roush0090 2005 - 2010 0 December 30th, 2009 08:07 PM
Blow Off Valve Backwash Guys With Fmic Come In ... turbot4 99-04 3 June 22nd, 2009 07:57 AM
need some pics of fmic installs please!!!! with bumpers off.. turbot4 99-04 16 May 28th, 2009 06:10 PM
fmic?and turbo? 87merkur 2.3 Mustangs 3 April 11th, 2008 12:14 PM
