Quick cel flash after prochamber install
Old February 20th, 2010, 07:45 PM   #1
slikirish's Avatar
2004 Mustang GT 5spd
slikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the roughslikirish is a jewel in the rough
I got the prochamber installed today and of course I've been driving around a good bit to listen to it. On 2 occasions the cel has just flashed on and off real quick. The cel was illuminated for maybe a second. It did it once while driving and the other time was while idling at my house. The dash scan doesn't show any codes except p1000 which I don't care about.
The tune I have has the rear o2s disabled and I know we plugged the front o2s in the right spot since they never came off the car. We unscrewed them from the stock h while still connected. The rear o2s wouldn't reach to be plugged in so we left them unplugged and zip tied out of the way until I order o2 extensions.
Is this just the the ECM picking up that the rear o2s aren't hooked up and then the tune immediately over riding that or is it something else? I've also noticed per the dash scan that the coolant temp is running a few degrees hotter than normal. Such as at an idle it peaked at 206 when it never used to go above 202. Is that possible related or could that be bc the tempature here is the warmest it's been since I started using the dash scan?
Mods in Garage
Old February 20th, 2010, 07:50 PM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
When the weather gets warmer it is hard to keep it cool at idle. Few degrees is nothing. Flashing ses light generally is a misfire code. Hows it running?
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old February 20th, 2010, 07:57 PM   #3
slikirish's Avatar
Runs great and doesn't feel like a misfire. It doesn't flash continuously it's just one quick flash and then doesn't come back. The lack of a code is a little odd to me as well
Mods in Garage
Old February 21st, 2010, 12:21 AM   #4
slikirish's Avatar
First page bump.
Mods in Garage
Old February 21st, 2010, 03:25 AM   #5
2000 GT
I have no clue man. Without seeing the code. It could be completely unrelated. Maybe a sensor is loose, and loses connection for a split second. You could try and plug in rear o2's even though they aren't used. I do, just so the wires aren't dangling (and need it to plug them up anyways). I would just make sure ALL sensors are plugged in crisply. Maybe check grounds too. And keep watching for the light/code...
Old February 21st, 2010, 03:26 AM   #6
Shaun03GT's Avatar
2003 Mustang GT
1/8 - 8.09 @ 91.39mph 1/4 - 12.35 @ 114.52mph
Shaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud ofShaun03GT has much to be proud of
iTrader: 11 reviews
Probally because the rear 02's are unplugged.
2003 Mustang GT Vortech V1 Intercooled
SAE Corrected - 380rwhp & 380rwtq @ 9psi
Uncorrected - 401rwhp & 400rwtq @ 9psi
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old February 21st, 2010, 12:23 PM   #7
slikirish's Avatar
Ive been thinking it could be the rears. Not to concerned so it's not even throwing a code. Seems like a tune issue. I'll report back after I get the extensions and get them hooked up.
Mods in Garage
Threads Similar to: Quick cel flash after prochamber install
Quick Question on ProChamber Lefty 99-04 11 December 27th, 2008 08:44 AM
how much to install shorty's and splice in prochamber 07stanggt 2005 - 2010 11 May 11th, 2008 05:32 PM
How To Install Prochamber??? laxdevil19 99-04 1 February 17th, 2008 03:35 PM
Quick Question about the MAC prochamber smokeysz4 2005 - 2010 8 August 28th, 2007 11:49 AM
Help! prochamber pipe install MnrlGry01gt 99-04 10 February 20th, 2007 07:35 PM
