n/a
ABS and brake light on 2000 Taurus
could use some help i replaced the brake booster because the pedal was hard as a rock didn't fix the problem so replaced the master cyl. and bench bleed it before installing it the bleed the front brakes didn't fix it so i found a melted vac. line and fix the line got brakes now but the brake light stays on along with the ABS light i know its not a mustang but im stumped any help would be appreciated.
2001 mustang gt
13.92
make sure the float in the res isnt stuck. it usually dosent cause the abs light to come on but its worth a shot
mods...k&n fipk, underdrives, flowmaster 40's, steeda tri ax shifter, pypes off road x-pipe. h&r springs coming soon |
unplug the connector on the master cylinder, make sure theres not a short in that connector.
usually both lights on is a sign of low/no fluid or a shorted fluid level sensor circuit
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
Threads Similar to: ABS and brake light on 2000 Taurus
| Anyone drive a 2000-2001 taurus? | dr.gonzo! | The Clubhouse | 6 | January 27th, 2010 10:56 AM |
| ABS Light? | DickH | 99-04 | 9 | November 26th, 2009 12:06 AM |
| Brake (ABS) Question... | An82Mustang | 99-04 | 8 | September 30th, 2009 09:10 AM |
| ABS brake bleeding | micldon | 99-04 | 10 | August 10th, 2008 02:29 PM |
| Where is the BRAKE LIGHT RELAY SWITCH on a 2000 Mustang???? | Mrs_Mustang | V6 Mustangs | 5 | August 15th, 2007 11:46 AM |
