#41 |
Try a stethoscope for a car, and just listen to where the noise comes from.
![]() Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp. |
#42 |
2000 GT
It's definately the belt.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#43 |
2001 mustang gt
13.92
baby powder if its the belt baby powder will make it quiet until it gets wet again. an old man that i used to work with showed me that trick.
mods...k&n fipk, underdrives, flowmaster 40's, steeda tri ax shifter, pypes off road x-pipe. h&r springs coming soon |
#44 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
.....This thread is full of funny stuff.Water is considered a solvent/called the "universal solvent" because most things will dissolve/be diluted by water. Considering it has a ph of 7 theres no way in hell its going to cause any issues with eating your belt such as a "real solvent" like lacquer thinner would. Figure out what youre gonna do ryan? The soap thing is a pretty good idea, worth a try as well. Same with the baby powder. Only down side I could think of due to the soap is once the belt gets wet its gonna be slippery as shit. |
#45 |
99 limited edition vert
I have had good luck running sandpaper along the edges while engine is running(have to be very careful) because most of the time with reoccurring belt noise there is a misalignment of the pulley's. If it was mine I would just replace the damn thing and not waste my time to temp. remove the noise constantly and look/correct the issue.
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
#46 |
2000 GT
Its not alignment, the noise is where it is smooth idlers, so it would adjust itself. Started when I got shit on it. Ill try the sand paper idea. It will rough it up and maybe take the surface off that is making the noise. If not ill just replace it.
And ya this thread cracks me up. Some good ideas though, some not! Belt was quiet untill I was cleaning the underside and got degreaser on it. Was instantly loud as hell. So ill do sand paper, and order new one if it doesn't make it better. Small squirt of water made it silent. And when belt is warmed up, about 2 miles of driving it shuts up.
#47 |
KB'd GT
You're gonna need a 8 rib setup to run more boost, or a WAY tighter belt. The blower is putting too much strain. Try moving the idlers to get the belt tighter. If this is the same size belt used for the stock boost, then you probably need to get a shorter belt. Belt slip can cause all kinds of weird issues, changes in alternator current, boost, etc. You need to do some RCA (root cause analysis) and solve the underlying issue that is causing the belt to squeak. I wouldn't think that degreaser would cause a belt to slip more, but maybe. You could wash it with detergent, and then rinse it very well.
#48 |
2000 GT
I have an 8 rib, with 2 idlers that are twice the size of stock ones they have with kit. Wraps the kb pulley about 65-70%. I nailed it with degreaser on the crank pulley. When i missed (was getting right below it). It started melting the belt, i had belt rubber on the idlers lol. Had to clean it twice. Was an "oh shit" moment and ran to turn car off.
I think it just f'd it up and put a residue or layer on it that is making a little noise when its cold. It was fine before i f'd it up. And degreaser was house brand. Shit was stronger than brake dust cleaner (thought it would be more mild).
#49 |
KB'd GT
Ok, got it. I would probably buy a new belt if it keeps acting up. Maybe you melted some ribs down a bit. That would really decrease the surface area.
#50 |
That sucks...Wasnt a good idea to hit it it with degreaser at all but shit happens.
#51 |
2000 GT
Yeah, it wasn't the game plan LOL. But shit happens.
And rib side was fine, its the smooth side that i nailed it with. I checked rib side and they are still golden. And not much of the smooth side was dissolved/melted off, can still see the writing on it. But apparently was enough to get rubber on the idler and make noise hehe. If it gets worse ill get a new belt. I need a slightly bigger one anyways. I can't put the damn thing on unless i have the tensioner pushed all the way, and take idler off and screw it on with tensioner torqued. Pain in the ass! Also i did the tensioner tab grind down to get me a lot better room, when running it is at the point of where the tab used to be (so way tighter than max).
#52 |
2001 Mustang GT
Little late, but the soap is just to determine that it is the belt, once you know that you buy a new one..why try to save an old belt? It's not like it's even relatively expensive?
![]() True Blue Crew Member #2 315's Crew Member (Dat azz) 255/298 Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club |
#53 |
2000 GT
Its not that old. Under 6 months
And i did the sanding trick with a rag to catch the dust. We'll see how it does when it is cold tomorrow morning!
#54 |
2000 GT
If belt is salvageable why not! Here's what i would need to get, rather spend 60 bucks else where :p Gates K080859HD Gates 8-Rib Micro-V and V-Ribbed Belts
#55 |
2000 Mustang GT Convert
Belt dressing - available at auto parts stores - its for that !
#56 |
2000 GT
Worked out good. Did the sand trick like limited said. Used pretty rough paper but made sure i didn't push hard. I had fine grain but didn't get results i wanted. I held a wet rag behind it to catch the majority of the dust.
Started it up this morning (when it is worst) and it was still doing it but VERY quietly compared to before. So i got a wet paper towel while it was running and held it on the belt and more shit came off. So i did that until it came out clean, then did the ribbed side just encase dust got on there. What do you know! Silent as soon as i was done, was like it flipped a switch.
#57 | |
2004 mustang gt
13.86@ 100.5 street tires
![]() The usual bolt on's.. |
#58 |
2000 GT
Yep try it out!
#59 |
Nice! Glad you got your
fixed.
![]() 99' Rio Red Mustang GT: --My Garage-- Check garage. Vortech V-1 intercooled running 9lbs of boost Life= eat, lift, eat, eat, eat, sleep, repeat
#60 |
2000 GT
Ha
Threads Similar to: Here's a different kind of question.. (belts)
| Different kind of suspension question...sorta | Cricket | 99-04 | 4 | January 19th, 2009 12:59 PM |
| bullitt question...kind of asap | energiesource | 99-04 | 47 | October 31st, 2008 02:07 AM |
| Different kind of tuner question | zinc02GT | The Clubhouse | 4 | September 23rd, 2008 09:53 PM |
| o/r h...different kind of question | mrbigjeep | 99-04 | 3 | September 21st, 2008 12:01 PM |
| Noob Question:What kind of differential do i have | 01 GT | 99-04 | 1 | May 28th, 2008 02:14 PM |
