2000 GT
Here's a different kind of question.. (belts)
Ok, so i figured out one of my squeals. And i think it is from the belt. Only happens from start up then goes away after a few miles. Got worse when i damaged the belt a bit with some degreaser hehe. I used a hose to figure out if it was pulleys (what it usually is) and sound is coming in between idler's and kb pulley. Not any of the individual pulleys.
Anyways, how can i test this theory? Im not spraying it with wd'40 lol. What about maybe a soaked cloth on the belt while it is running? Would that work you guys think? Don't want any chemicals that could add to supercharger slip...
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) Last edited by RyanGT; February 23rd, 2010 at 11:38 PM. |
2000 GT
Lol, i said not wd40!! Probably what caused it in the first place (when idlers acted up i sprayed the shit out of it many times).
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
Hooo Ha Ha
+1
Squeek Squeek Squeek *spray* Silence.... You found your pulley
![]() 410rwhp 520rwtq @ 12.9 psi |
2000 GT
wd 40 was short term. Made those pulleys squeal like crazy after awhile. But they are replaced. I think it is the BELT, i don't want to spray the belt with wd40. My boost would go from 16 to 10. I would be slipping like... baker!!
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
i was jk. i have no idea lol
KY?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone |
Hooo Ha Ha
Grease all the pulleys. With legit grease.
Dont spray the belt whatever you do. It ruins the belt
BYAHHHH!
2001 Mustang GT
13.874
KY - inproving Bakers GF sex life since 2005
2000 GT
/cry
Want to test belt not pulleys. I think belt is trashed with all of the shit that has got on it over time (mostly wd40 from idler problem).
2000 GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
white lithium grease?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
2000 GT
Im kinda scared of any grease/lube. Do you think water could work as a short 1 min trial thing? Grease would get on the pulleys and shiz.
#16 | |
Hooo Ha Ha
Grease. It wont hurt anything trust me. You might gain 1 hp from it if you do all your pulleys.
#17 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Only to test the belt similar to if you sprayed it with wd40. Put it in a squirt bottle, set the nozzle to a stream rather than a mist, then squirt just the belt. The water will act like a lubricant to shut it up for a second if the sound is indeed from the belt. I wouldnt go running the water hose on it or similar. |
2000 GT
Why not water? Im sure water splashes on crank pulley and gets belt a little wet every once in awhile? And how would grease on the belt giving me slip on the kb give me hp :p Thats my reasoning hehe. Water will go away, but lube will stay on that shit.
Hooo Ha Ha
I ment greasing the pulleys. Water will be ok on the belt
2000 GT
Yeah thats what i was leaning towards ajm. Definitely not soaking the thing with a hose, more like a little big from a soaked rag or water bottle.
Threads Similar to: Here's a different kind of question.. (belts)
| Different kind of suspension question...sorta | Cricket | 99-04 | 4 | January 19th, 2009 11:59 AM |
| bullitt question...kind of asap | energiesource | 99-04 | 47 | October 31st, 2008 01:07 AM |
| Different kind of tuner question | zinc02GT | The Clubhouse | 4 | September 23rd, 2008 08:53 PM |
| o/r h...different kind of question | mrbigjeep | 99-04 | 3 | September 21st, 2008 11:01 AM |
| Noob Question:What kind of differential do i have | 01 GT | 99-04 | 1 | May 28th, 2008 01:14 PM |
