99-04 SRA to IRS swap mix matches...
Old February 28th, 2010, 06:04 PM   #1
14.10 @ 98
Stephen4036 is infamous around these partsStephen4036 is infamous around these partsStephen4036 is infamous around these parts
Send a message via AIM to Stephen4036
After completing an 8.8 to IRS swap I thought I would just say a few things to help people out who plan on doing this in the future..
Odd tools needed..
8mm Allen wrench SOCKET (8mm Allen Wrench piece that goes on your 3/8's ratchet).
Air tools would be great for the big brackets that come with an IRS, if you don't have a big pipe or breaker bar as it took an impact to remove.
Caliper/Rotor comparison...
I was told the calipers are the same with just a bigger rotor..
this statement was wrong... it is a bigger rotor so i decided to use my calipers and slide them into his brackets.. if you decide to do this as well you will need to run to a parts store an get the GT/V6 Caliper pin/bolt kit.. aka the pins/bolts that hold the caliper to the bracket. Also make sure you grease those pins before installing the caliper.
Brake lines, stock lines are used but you may have to bend them around the shock of the IRS (bending the metal part obviously).
Also remember to re-attach your e-brake! I figure that out the hard way...
other than that you don't have to drill any holes if your GT is 99-04... and it is a direct bolt in!
If this is helpful just sticky it.
[SIGPIC][/SIGPIC]
[LEFT][B][COLOR="Red"]4r70w to TR3650 Swap...[/COLOR]
[COLOR="Red"][COLOR="Yellow"]SRA to 2001 IRS Swap...[/COLOR][/COLOR]
[COLOR="Orange"]2000 2v to 98 4v Swap...[/B][/COLOR]
[COLOR="RoyalBlue"][B][I]there really isn't much else to swap... :cool:[/I][/B][/COLOR][/LEFT]
Old February 28th, 2010, 07:28 PM   #2
86er's Avatar
Was amazed at how easy it went in. It took me pretty much by myself, occasional helping hand to push or pull about 30 min to get the IRS from the ground to totally bolted into the car.
As he said, the caliper bolts/slide pins are just a smidge different from the GT to Cobra, other than that hang up it was a lot easier than I had anticipated putting this in for stephen
Just a truck
Old February 28th, 2010, 07:29 PM   #3
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
whats up doug lol
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old February 28th, 2010, 07:31 PM   #4
14.10 @ 98
Originally Posted by 2kCammed2v View Post
whats up doug lol
you shut your whore mouth jaryd! you didnt even show up to help us!
[SIGPIC][/SIGPIC]
Old February 28th, 2010, 07:36 PM   #5
86er's Avatar
whats up doug lol
glad you helped, whats up man, come out this tuesday, Its my last tuesday for a while
Just a truck
Old March 1st, 2010, 10:36 AM   #6
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
Why didn't you just use the brakes and stuff that came on the IRS?
Isn't it basically just four bolts to drop the IRS out? I have an IRS from an '03 cobra that I thought about using in my '04 GT, unless someone wants to buy it
Do the Right Thing, Cook. ~Zip.
Old March 1st, 2010, 12:43 PM   #7
SS Ball3r will become famous soon enough
wow, i didnt realize it was that simple of a swap. i might just look into this now.
Old March 1st, 2010, 12:57 PM   #8
86er's Avatar
the cobra brake calipers had been ground on and he didnt want that pokin through the wheels, cant blame him, Stephens car is CLEAN.
Just a truck
Old March 1st, 2010, 12:58 PM   #9
86er's Avatar
It really is, you have to unbolt the quad shock mount, mount a bracket there, then you put the IRS where the lower control arm mounts and into the brackets that replaced the quad shock mount.
Then you just attach the shocks in the stock spot, you can use the gt brake likes too. Just make sure you get the abs sensors for the IRS, different location, but hook up to the GT connector
Just a truck
Old March 1st, 2010, 02:33 PM   #10
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
Yes the install isn't bad at all, but it's heavy as shit, so make sure you have some friends to help you take it out of your truck/suv.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old March 1st, 2010, 03:10 PM   #11
good stuff. Im definatly looking into this now especially since i am into road racing/autox.
Old March 1st, 2010, 03:13 PM   #12
MyGT's Avatar
13.1@105
MyGT has a spectacular aura aboutMyGT has a spectacular aura about
iTrader: 7 reviews
Hey Stephan, sorry about the brake caliper thing, my calipers bolted right in
Also nice to meet you Doug, and thank you for the immense amount of help lol
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees!
Old March 1st, 2010, 03:21 PM   #13
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
Did a car to car swap over the weekend. Very good experience in learning what to do and not to do.
I am seriously considering going solid axle on my car. Sucks because I have 4.10s, bushings, and IRS brace that I would lose.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old March 1st, 2010, 03:26 PM   #14
mustang_gtr_99's Avatar
1999 3V GT/2007 GT D/D
corner carver
mustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the roughmustang_gtr_99 is a jewel in the rough
glad to hear it went well. Even though I do auto X I still dont want the IRS. Thing weighs a ton and similar handeling characteristics can be had with the SRA using a number of aftermarket packages that dont add all that weight. Extra weight is your enemy in Auto X. It has a big part into how much speed you can carry through a turn
OS2 (SW) USN
REAR SEAT DELETE FABRICATOR
"RSD pics in garage"
99 3V GT/2007 GT DD
Old March 1st, 2010, 04:30 PM   #15
iTrader: 7 reviews
You can swap over your carrier so you keep the 4.10s. You'd get a good chunk of change for an IRS with upgraded bushings and a brace, more than enough to buy a SRA
Old March 1st, 2010, 04:48 PM   #16
86er's Avatar
its cool, yeah the slide pins were the only difference, you had the GT slide pins with a bigger "notch" missing from the head, no big deal, not a world stopper.
Anytime on the help, def not my first go around ripping shit out of one
Just a truck
Old March 1st, 2010, 09:06 PM   #17
01 Cobra Vert
Nov 09/10 ROTM!
Good tip Thanks. Reps.
I will probably get rid of it as is if I do and just get some 4.30s.
Military Crew E5
Old March 1st, 2010, 09:15 PM   #18
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
I'm going to beat your ass if you go over to SRA
Old March 1st, 2010, 09:18 PM   #19
01 Cobra Vert
Nov 09/10 ROTM!
it's only a thought right now. My car is still a mall cruiser. But damn homie, traction and no hop with just a stock SRA. If I do it, I will start buying new control arms and everything I could before I did the swap.
Military Crew E5
Old March 1st, 2010, 09:19 PM   #20
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
You can fix the wheel hop bitch
Threads Similar to: 99-04 SRA to IRS swap mix matches...
Anyone with IRS or wanna do the SRA swap READ THIS!!! Diabeetus 4V / SVT 11 February 28th, 2011 10:20 PM
Swap SRA for IRS dcook_14 4V / SVT 34 May 20th, 2010 12:05 PM
IRS to SRA 99cobra! 4V / SVT 23 May 30th, 2009 03:12 AM
irs to sra swap 03snakeminated 4V / SVT 24 March 4th, 2009 11:49 PM
SRA back to IRS swap...spring issues..HELP!!! matted2thefloor 4V / SVT 4 August 4th, 2008 07:26 PM
