Driveline noise Vid inside
Old March 6th, 2010, 07:37 PM   #1
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Ill try to make this short. Recently I put in a new Spec Stg3 clutch setup with a new flywheel and a ford tob. I tripple checked everything and torqued everything to spec. Everything went smooth. I did the normal break in 500miles and Ive had a noise since, No odd noises.. etc before the swap. It gets louder with speed. But I cannot tell where its coming from...sometimes it sounds like its coming from the tailshaft of the trans and other times it sounds like its from the rear. It seems to echo thru the driveshaft. I pulled the inspection plate for the clutch and everything moves freely and no noise seems to be coming from the clutch area. Ive had 2 other people poke their head underneath just to be stumped also. I pulled the tailshaft seal to inspect the splines on the tranny and look for marks on the yoke....nothing found. Replaced the fluid with GM syncomesh also. Also tried repositioning the driveshaft.
This was the best vid I could get but its kinda hard to hear over the exhaust.
Bolt on list in Garage..
Old March 6th, 2010, 08:57 PM   #2
The Mean Green
MATT02GT's Avatar
Anyone???
Old March 6th, 2010, 09:01 PM   #3
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I hear it. It is that high pitched metallic sound. I have no idea though man. Sorry. I have a similar issue with my Jeep at the moment to be honest.
Old March 7th, 2010, 06:42 AM   #4
The Mean Green
MATT02GT's Avatar
Its so wierd...its like its coming from the driveshaft itself
Old March 7th, 2010, 10:12 AM   #5
Roush00's Avatar
2000 Roush Stage II #2568
Roush00 will become famous soon enough
What Trans do you have? I noticed you said you filled it with syncomesh.
2000 Roush Stage II With Some Mods
Old March 7th, 2010, 11:27 AM   #6
Hot66Rod's Avatar
2003 Mustang Gt
1/8 mile is 8.424@81.52
Hot66Rod is on a distinguished road
possibly a bad throw out bearing
Mods In Garage
Old March 7th, 2010, 04:10 PM   #7
The Mean Green
MATT02GT's Avatar
I have the TR3650.. And I put in a brand new Ford oem throw out bearing, and theres no noise coming from it when look through the big inspection hole
Threads Similar to: Driveline noise Vid inside
got my ezhaust on (vid inside) Squints 5.0 Mustangs 5 July 27th, 2008 02:19 PM
Mofo vid: Acmillr inside!!!! Racerchik02 Racer's Corner 23 February 15th, 2008 08:13 AM
I am sad...vid inside 1SLO85 Videos 13 June 13th, 2007 10:04 PM
