Stripped exhaust manifold stud
So as i was bolting my exhaust back up my effin air gun stripped the top threads on one of my exhaust manifold studs, and now i have this horrible exhaust leak and my car sounds like shite. Any suggestions on how to replace it would be greatly appreciated.
2000 GT
Pull it all apart, and use locking header bolts. I pulled out all of the studs out and used stage 8 locking when i did my header install.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2000 GT
Shit, half my studs came out when i unbolted my manifolds lol.
Wait do you mean bolt for the manifold (to the block) or from the midpipe?
the ones that connect to the midpipe, on the pushrod motors its simple to replace them but on the modulars it looks like i have to pull the motor to get to the studs. I swear, if i have to pull the motor to get to the effin stud im done with modulars and im putting my 351 in it.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
If the threads are stripped at the top and still good on the bottom just double nut it and hit it with an impact. May also help to heat it and/or spray it with some pb as well where it threads into the manifold.
1998 Mustang GT
1:34.43@13.86
why would you ever use an impact wrench to loosen any bolt that goes in the the block or heads? thats bad policy, u should use a breaker bar or somethin next time with a little wd 40 or PB blaster.
![]() "The only way to learn about a car truly is to break something and fix it yourself..." |
Moderator
is the stud top of the stud itself stripped as well? if not then you can get a 5mm socket on there and then unscrew it to replace it.
![]() ![]() BUILD 2 IN PROGRESS |
2001 mustang bullitt
Just replace the stud bolt or replace with locking header bolts.
I used regular header bolts and have not had a problem,but I re tightned them after I let the car run for bout 20 mins and let it cool down and used metal gaskets also.
2001 bullittmmr 900 LB,stg 2 blwr cams,spec clutch,alum flywheel,novi 2000,intercooled,gt pump,80lb injectors,3:73gears,bbk ceramic shorties,bbk xpipe,bbk 65mm tb,flowmaster catback,steedatriax.eibachsprings,m&m lower control arms,ford alum ds. Last edited by dcrow; March 7th, 2010 at 10:52 PM. |
Threads Similar to: Stripped exhaust manifold stud
| ok to reuse exhaust manni stud/nut | mrblueoval | 99-04 | 16 | January 30th, 2010 11:29 PM |
| Quick manifold stud/bolt question | winnie51189 | V6 Mustangs | 1 | November 3rd, 2009 02:09 PM |
| Pictures of stripped stud | MustangMatt96GT | Pictures | 4 | June 6th, 2008 01:50 PM |
| Exhaust Manifold | joe_shizzle | V6 Mustangs | 9 | April 12th, 2008 12:38 AM |
| Well I stripped a stud! | MustangMatt96GT | 96-98 | 21 | September 20th, 2007 07:29 PM |
