345-35-18
What do i need to run these tires on my 2000 gt. i have some 10.5 deep dish bullits. thanks
Abyssinian of AX
'02 Saleen
19.34@42.259
You will run into problems running that tire on your ride
![]() That tire is 1" larger than OEM and MUCH wider. It is also a VERY poor fit on a 10.5" wheel and recommend you get a tire that is properly sized for the wheel so it will perform correctly. I recommend you go 305~315 in a 30 series on an 18" wheel. Jazzer
well whats the widest i can go with a 10.5 wheel.
Noob Slayer
13.82 @ 101.09
i wouldnt go wider than 325. 315 ideally.
![]() 2003 Black Cobra 10th Anniversary 2.8 Kenne Bell Mammoth LC - Built SRA - T56 - E85 - Spray - Stock Longblock - True Forged Mach 5s 2004 Silver GT 5 speed - SOLD MM Cobra Club Member# 97 |
Priest of the Car Gods
325 is even pushing it a little bit on a 10.5" wheel.
thats a large tire to want to run.
but either way 315 would be the best fit. if you are set on running 345. then i would get at least an 11 inch wide if not 11.5 in
any one has any pics of some 315's or 325's
what he said. a 315 is perfect fit on a 10.5 but a 335 will fit with a little bulge
will a 315 even fit without rubbing on an 18" rim?
Project Mongoose 427 rwhp 411 rwt //www.cardomain.com/ride/2673478/1 http://www.moddedmustangs.com/forums...-member-32306/ |
04 mustang gt
7.21 @ 98
here are 325's...on 10" rim.
![]() cams + 150 shot |
Threads Similar to: 345-35-18
| 345/30/18's on 12.5" bullitt wheels.... | the real shocker | 99-04 | 38 | January 4th, 2012 07:53 AM |
| 345, 351, or 460 | Iwannagofast | 5.0 Mustangs | 34 | April 28th, 2009 04:19 PM |
| 345 hp stock | DeMello | The Clubhouse | 13 | June 13th, 2008 04:54 PM |
