Cam?
I have a 2000 gt. its got about 10k since i rebuilt the motor. which is the biggest cam can i put on the stock heads without having to do any major modifications.
eating 1 ricer at a time
2002 mustang GT
not sure only ran on the streets so far!
![]() ![]() ![]() iTrader: 3 reviews
Stage 2 I believe
Power in the hands of a few ![]() Buy your coffee from 02gt89 I guarantee better than starbucks click here |
04 mustang gt
7.21 @ 98
most stage 2's will probably work. i would guess around 5.50 lift or maybe a little more would be about the biggest
i have the hitech stage 2 cams which are 5.45" lift and like them.
![]() cams + 150 shot |
Depends on the cam profile. I've been looking into Modular Head Shops info. It's worth the read if you have the time.
Cams: ModularHeadShop Bullet Cams 4.6 NA cams FAQ: ModularHeadShop 2V Cams FAQ |
will the comp cams extreme energy( i think thats what they are called) 270 fit without piston valve contact?
#6 | |
2002 mustang GT
i saw them in a summit racing catalog i had lying around, but thanks for the link.
edit: The ones american muscle has arn't the ones iwas looking at, but thanks anyways. Last edited by SS Ball3r; March 7th, 2010 at 03:47 PM. |
#8 | |
2002 mustang GT
Boost gets you laid
i think the comp 270 is the biggest you can go without upgrading valvesprings. pretty much any stage 1 cam will go in, but some stage 2's and bigger require valvesprings to go with them. your best bet is to ask the manufacturer
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
2001 Bullitt
12.25@110.4
270's will barely fit as long as they're degreed in, same with CMS/VT Stage 2's. The new version of Hitech Stage 2's and the MHS Stage 2 will fit with no problems.
There is a huge lip on the factory intake valve which can be machined off, or replaced with aftermarket valves, which will give the 270's or CMS/VT's a little more wiggle room. I have a set of the original VT Stage 2's for my car, but will not install them until I can afford to swap out the intake valves, even degreed in, it's about .005 clearance on most engines, which is just a bit too close for my comfort. |
Threads Similar to: Cam?
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 10:36 PM |
| 289 cam vs 351 cam | Kenn | Classic Mustangs | 11 | May 5th, 2008 01:20 PM |
| N/A Cam and Blower Cam ??? | StuTheMusicEngineer | 99-04 | 1 | March 3rd, 2007 04:35 AM |
| E cam or F cam horsepower and 1/4 mile time questions | GreyGhost | 5.0 Mustangs | 1 | August 21st, 2006 06:25 PM |
