Hooo Ha Ha
Sharkbait needs help, im stumped.
Ok so today I took my car out for its very first track day. Also happend to be my first day at the track.
Before today if my car got too hot at high rpm and full boost it occasionally feel like im losing power... kinda like its not pulling but rpms are going up. Sometimes it would just do it in little spurts. Well today it started to do it again but now its after 4200 and its all the way up to 6k. It feels like its stumbling and like i have no power. I am having a hard time describing it but it feels like it just dosnt have any more. I am thinking its spark blowout but im not sure. I think my plugs are .54 right now. Platnuim plugs. But i dont know if thats it or not. I cant afford to just change them and see as i am very very broke. REPS FOR ANY USEFULL INFO
![]() 410rwhp 520rwtq @ 12.9 psi |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
if they are gapped that big then i think you have found your problem. Thats way too much for a blower.
.... get it down around the .032-.035 range brutha.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
mine was blowing out like crazy when i first installed my blower and was doing the exact same thing in the higher rpms till i found out it needed to be tightend up.
2000 GT
2 Problems. Plats are no no's with boost. And gap is too much, but you can't change plat's gaps since it just smashes the nipple. Swap em out with cheap coppers and you will be good to go!
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
2003 Mustang GT
12.78@106.44
Hooo Ha Ha
Alright tommarow i think il buy a set of coppers.
Would NGK be preferred? And autolite and mastercraft be good also? Now as a reward for you all helping me
2000 GT
I run NGK tr6 with no problems. Honestly at 6psi i wouldn't sweat what brand to get, even at 9. Some don't like the ngk's and like champs or autolites.
I realllllly want to try the zex plugs.
im a fan of autolite. autolite 103's are what i used to run. I will say though, that im not running a 2 stage colder NGK plug with no problems so either will be fine!
2000 GT
Baker when do you run a 2 step colder? Any ideas? Never really found out... i know 2 power adders you do, but not sure what boost level you tend to.
Hooo Ha Ha
So your all fairly sure this is infact spark blowout?
2000 GT
If it isnt blow out it is a shitty spark. Plats SUCK bad with boost. Combine it with N/a gap and you are bound to not be getting a good spark.
Hooo Ha Ha
Alright, cause i have msd coils and Frpp wires. I'll try this tommarow and see what it does.
IF it isnt blowout what could it be
2000 GT
If it isnt spark blow out (should be replaced regardless) i would say inadequate fuel. Start at fuel filter. Or datalog it at wot would be best option to figure it out.
Hooo Ha Ha
Its got a 255lph pump, new fuel filter and 30lbs injectors and its tuned with a 11.2 a/f and it pops rich codes bi weekly.
2000 GT
Then your rich fuel isn't being sparked
And damn that is rich!
2000 GT
Tell us how it goes tomorrow. Ill be not paying attention in class and be waiting for people to post shit on MM
ryan.... my tuner told me to put them in so that he could get more timing out of it at those power levels. SO i did it. dont really understand all that.
1998 Mustang GT
13.046@107.49
colder plugs decrease knock. Decreased knock means you can add more timing. At least that's how I understand it. You do have to be careful though if you live in colder areas. I have a buddy that has a grand prix gtp with three stages colder plugs and his car won't start if it is below 30 - 35 degrees out.
98 Mustang GT 13.795 @ 98.87 N/A Main mods: PI Swap, 3.73 gears, E85 ![]() My Mark VIII and T56 swap |
#19 | |
Abyssinian of AX
'02 Saleen
19.34@42.259
Jazzer wants his reps now
2000 GT
lol jazzer you crack me up.
Baker: Gotcha, im curious if i should or not when i replace plugs
Threads Similar to: Sharkbait needs help, im stumped.
| i am stumped | Danderson | The Clubhouse | 5 | February 4th, 2009 02:45 PM |
| Need help, I'm stumped!!! | Haggis13 | 5.0 Mustangs | 17 | August 12th, 2008 09:22 PM |
| stumped... | jessy_is_rad | Classic Mustangs | 19 | April 30th, 2007 01:13 PM |
| Okay, I'm stumped | SoonerBorn | V6 Mustangs | 18 | March 10th, 2007 02:20 AM |
| I need help im stumped | PonyRunner | Classic Mustangs | 1 | February 19th, 2007 01:59 PM |
