#21 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
for the price of your discarge tube you can make an a/a ic with a blow threw maf set up. get the v3 si cause it is a way better unit than the v1. if your not running a bap use a ford gt pump with a gates fuel hose.
#22 |
2003 mustang v6 ;)
slow
home made power pipe for cheap
cxracing.com: 4" Aluminum Pipe 45 Degree Bend, Polished, Mandrel Bent, 3.0mm Thick, 24" Length this pipe Reducer Elbow this reduser Silicone 45 along with this reduser trim to fit and done. if you need bungs you can get aluminum pipe sections cut to size from this site Aluminum Pipe | Cut 2 Size Metals - ESMW done! |
Threads Similar to: vortech questions (Fuel pump, power pipe and others)
| stock gt, vortech, FUEL PUMP, INJECTORS, and MAF UPGRADE???? | oonegtstang | 99-04 | 26 | January 21st, 2010 10:56 AM |
| Power pipe + vortech | 00 Steeda | 99-04 | 8 | April 13th, 2009 10:19 PM |
| Fuel Pump For Vortech SC GT | supercharged03gt | 99-04 | 35 | January 22nd, 2008 10:44 AM |
| Fuel Pump Still Not Getting Power At Relay | Illuminator | 5.0 Mustangs | 11 | December 29th, 2007 01:38 AM |
| No Power To The Fuel Pump | rage | 5.0 Mustangs | 3 | September 20th, 2006 03:37 PM |
