![]() iTrader: 1 reviews
So..now I have a P0300
I'm throwing a P0300 code now, which i think is random/multiple cylinder misfire. It just started randomly and now it wont idle it just wants to die so where do i start? spark or fuel, but thats alot of checking.
well that narrows it down, but id like to narrow it down even more. i recently had some idling issues caused by a bad o2 sensor. i replaced them both and the car was running fine, and then driving it for a few hours this happened.
Take your neg terminal off the battery for about 30 seconds and hook it back up. See if that helps at all.
i did that after i installed them but ill try it. it was running pretty shitty. when the light came on, it was shaking the car alot.
i started it up and let it idle and it runs fine now. the ses light is still on though. the engine shakes a bit but i suppose no more than it did...maybe just a fluke? anything in particular i should check
When's the last time you checked/replaced your spark plugs? I would at least inspect each one.
I replaced them when i did my cams back in sept but havent driven the car this winter so there shouldnt be anything wrong with them
2004 Mustang GT 5spd
I wouldn't count that as a fluke. Most likely cause is a plug, COP, injector, or fuel filter
Mods in Garage |
How about fuel filter? A clogged fuel filter will make it a little difficult to get the correct amount of fuel. And if it sat all winter the fuel could have gone bad.
Missed the part about sitting all winter. Did you put any kind of fuel stabilizer in it? If not try draining the tank and filling with new
Mods in Garage |
Hopefully it's just some bad gas or fuel filter issue. Fuel filter is easy enough to replace though.
dont you have to take out the tank to get at the fuel filter?
No, it's right there by the fuel tank, no need to drop the tank. Just make sure you disconnect the battery and bleed the line at the schrader valve. Or you can pull the fuse for the fuel pump and start it up until it dies to clear the lines and then disconnect the fuel lines on the fuel filter. I would recommend wearing some goggles to protect your eyes to be safe. Nothing sucks more than getting fuel in your eyes.
2000 GT
No, its sitting under the car between the axle and tank. That is probably one of the causes if you don't know where it is (hasn't been replaced). I would definitely start there. Cheap and very easy. The butt end of our cars are fairly high up, so you might not even have to jack it up to get to it. You will need a fuel disconnecting tool.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#16 | |
2000 GT
IIRC, I believe you need a 3/8s fuel disconnect tool. Or if you don't have one on hand like I did when I installed the blower for a second time on this Bullitt, you can buy a funnel and saw the tip off, cut it long way so you can wrap it around the fuel line and push in to disconnect the line. ...Isn't hillbilly ingenuity great?!
#18 | |
Ouch man, I think I felt that.
#19 | |
It couldn't hurt depending on how many miles you put on it between now and then. I replaced one on my old Bullitt when I did the blower install and when I tipped it up to drain the residual gas out of it dark fluids were coming out. It was very dirty.
Threads Similar to: So..now I have a P0300
| P0300 | mcqueen | V6 Mustangs | 15 | February 17th, 2010 02:42 AM |
