Water and white smoke - Page 2
Old March 11th, 2010, 04:39 PM   #21
eating 1 ricer at a time
02GT89's Avatar
2002 mustang GT
not sure only ran on the streets so far!
02GT89 has a spectacular aura about02GT89 has a spectacular aura about02GT89 has a spectacular aura about
hmmmm
Was ur car run out of oil?
Was it run out of anti freeze?
Was it over heating?
How much did u over rev it?
Beauty and Speed - SALEEN
Sig by Zatrekaz
Old March 11th, 2010, 04:53 PM   #22
ReikokuKo's Avatar
2001 Mustang GT
ReikokuKo is on a distinguished road
Send a message via AIM to ReikokuKo Send a message via MSN to ReikokuKo Send a message via Skype™ to ReikokuKo
Dang, youtube is taking its sweet time. I never really over-rev it. The only time I can think of is when I floor it or launch it, it will redline before changing gears. But I don't do that very often.
I've actually lost quite a bit of coolant. Also I checked my oil dipstick and it was past full. Just something I thought was out of the ordinary.
Old March 11th, 2010, 04:57 PM   #23
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
both of those point to a blown gasket or cracked head, if wasn't for the excessive smoking I would have suspected the oil cooler area(if you have one, if not that gasket) it's rare the 4.6l blowing a head gasket,n/a
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old March 11th, 2010, 05:00 PM   #24
ReikokuKo's Avatar
2001 Mustang GT
Originally Posted by limited View Post
...it's rare the 4.6l blowing a head gasket,n/a
Just my luck. I sure hope its not a cracked head though. Is it safe to continue driving it and just keep adding coolant?
Old March 11th, 2010, 05:05 PM   #25
limited's Avatar
antifreeze and bearings are not a good mix, I would fix asap
Old March 11th, 2010, 05:12 PM   #26
ReikokuKo's Avatar
2001 Mustang GT
Has anyone heard of or tried Steel Seal?
Old March 11th, 2010, 05:18 PM   #27
02GT89's Avatar
2002 mustang GT
nope and if your loosing antifreeze thats bad... also check your anti freeze and make sure theres not Oil in it if there is you have a cracked head! and thats BAD! your looking anywhere from 500- 1000+ fix x.x for a cracked head. and a fix for a head gasket prolly wont cost any where near that I am not sure never really dealt with those that much head gasket will vary
Sig by Zatrekaz
Old March 11th, 2010, 05:22 PM   #28
ReikokuKo's Avatar
2001 Mustang GT
My antifreeze had its normal color. It was just low.
This Steel Seal and ThermalWeld stuff, you supposedly just pour it in where your coolant goes and it will seal cracked heads and blown head gaskets. I've been searching around and a lot of people who have tried it are saying that it works. I just wanted to see if anyone here had tried it since I trust the people here more than what shows up on google searches.
Old March 11th, 2010, 05:26 PM   #29
limited's Avatar
I don't know the product you are talking about, but I have used silver solder stop leak fix and it has worked for me on several occasions, however it should only be used as a temp repair till you get it fixed, no stop leak product is a perm. fix
edit: I think thats the name of it, looks like metal shavings in a tube
Old March 11th, 2010, 05:36 PM   #30
02GT89's Avatar
2002 mustang GT
It may work.. but like Limited said . it is a very temporary fix. you still need get your car fixed asap before more harm is done. and if your car has a blown head gasket I wouldn't drive it you will end up tearing up more crap and no body want's that
Sig by Zatrekaz
Old March 11th, 2010, 05:54 PM   #31
ReikokuKo's Avatar
2001 Mustang GT
Well, I'm going to attempt to change out the head gaskets myself this weekend. What's a good list of things I will need before I get started?
Old March 11th, 2010, 06:43 PM   #32
02GT89's Avatar
2002 mustang GT
HMM i am not sure I have not done this repair by myself
Sig by Zatrekaz
Old March 11th, 2010, 06:43 PM   #33
02GT89's Avatar
2002 mustang GT
let me get someone in here to help with that
Sig by Zatrekaz
Old March 11th, 2010, 08:45 PM   #34
ReikokuKo's Avatar
2001 Mustang GT
Well, here's the video just to be sure beyond any reasonable doubt.
Old March 11th, 2010, 10:13 PM   #35
02GT89's Avatar
2002 mustang GT
1. love ur cars sound.
2.that's a very mild white smoke.
3. Stick ur finger inside ur tail pipe (not when its hot) and see if U feel water! That looks more like condensation!
Sig by Zatrekaz
Old March 11th, 2010, 10:23 PM   #36
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
we have a lot more condensation now due to the poorer quality of gasoline. You should be ok. Thick white smoke, like enough that you cant see anything at all through it, then you should worry
Old March 11th, 2010, 10:25 PM   #37
02GT89's Avatar
2002 mustang GT
+! what he said... if you have any serious issues. you will start to notice right away.. of you have a bad head gasket you will overheat.
Sig by Zatrekaz
Old March 11th, 2010, 11:16 PM   #38
ReikokuKo's Avatar
2001 Mustang GT
Well, that is great news. I haven't really noticed any performance degrades. But how do I explain the lowered coolant levels? It wasn't terribly low, my mechanic put coolant in it last and I never looked so I don't know how much he put.
There is one thing I noticed, it could be completely unrelated, but when my engine is warm and I change gears, say from Drive to Reverse, my tach dips below 500 then comes back up to normal idle. Or when I'm at a complete idle, and I gas it and release really quick, after I release my tach will dip down and only once did it dip down low enough for my engine to stall.
I will finger my exhaust later on tonight to check for water.
Old March 11th, 2010, 11:33 PM   #39
02GT89's Avatar
2002 mustang GT
hm... It shouldn't dip low enough for it to stall on an a/t .. how ever it will go down .
Sig by Zatrekaz
Old March 12th, 2010, 12:02 AM   #40
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
Damn and I was worried for you for a second. My car smokes worse then that! LOL.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Threads Similar to: Water and white smoke
White Smoke RC04SVT 99-04 7 October 15th, 2008 01:31 PM
White smoke?? smokeshow 99-04 14 May 24th, 2008 10:52 PM
That white smoke ByPopularDemand V6 Mustangs 19 April 19th, 2007 11:56 AM
white smoke zero 5.0 Mustangs 47 March 20th, 2007 12:22 AM
white smoke? ByPopularDemand V6 Mustangs 31 March 6th, 2007 03:15 PM
