Rear End
Old March 12th, 2010, 05:24 PM   #1
MATT02GT's Avatar
MATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the roughMATT02GT is a jewel in the rough
Rear End
So Ive got some bearing noise coming from the rear end But anyways if Im gunna tear into it, its getting upgraded. Im putting over 400hp the the wheels and plan on more in the future so Im wanting to build something bullet proof without breaking the bank. I want to up grade to a 31 spline setup with a diff that lets me drive it on the street but also will take some punishment at the track. So im just looking for some different combos/ideas you guys might be running. I want to keep it in the $400-500 range and I plan on reusing my 3:73 gears and also welding the axle tubes while I'm in there. Any input would be great, thanks.
Bolt on list in Garage..
Old March 12th, 2010, 05:31 PM   #2
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
I bought my cobra diff, diff cover, and 3.73 gears from Ford Racing Parts and Accessories at great prices 31 spline moser axles from AM. I think I spent just under 1k or a complete built rear end.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old March 12th, 2010, 05:35 PM   #3
ITS ME DAVID's Avatar
ITS ME DAVID is on a distinguished road
ow man rwhp can that rearend handle..
please Visit MyYouTube Profile Below
http://www.youtube.com/adjmproduction
Old March 12th, 2010, 05:38 PM   #4
I'm not sure, but it's holding just fine on my DRs with 2400 launches.
2001 Bullitt #5069
Old March 12th, 2010, 06:24 PM   #5
ajm
With a budget of 450-500 id do this if youre set on a 31 spline setup
used 31 spline diff from the junk yard or similar, then rebuild it with the carbon clutches and replace the bearings. Prolly cost you $150-175 total. Or buy one for about $240
31 spline axles - $275 or so
and personally if at all possible id throw on a rear griddle and stud kit for the bearing caps.
that should make it quite healthy.
Old March 12th, 2010, 10:12 PM   #6
MATT02GT's Avatar
I did plan on the rear end girdle also outside the budget. I found a used 31 spline auburn diff for 200 bucks so I might look into that. How hard is it to rebuild a diff? Im pretty mechanicly inclined, just never had a chance to play with a diff. Also where would I find a 31 spline diff in the junkyard, Explorers and F series trrucks?
Old March 12th, 2010, 10:19 PM   #7
Hot66Rod's Avatar
2003 Mustang Gt
1/8 mile is 8.424@81.52
Hot66Rod is on a distinguished road
are you sure its a bearing noise you got...i thought it was in mine and rebuilt the whole rearend and i shouldn't have cause the guys that done mine fucked up the gears and it still didn't stop the noise and now my gears whine...but i found out what the noise was and it was the brake caliper...it was locking up...just a thought...and you can buy a cobra diff off ebay really cheap...i bought mine for 60 bucks and bought some used mosser axels for 120 and bout gears for 150...then paid a guy to put the gears in for 300 and they messed up the gears...the install kit cost 80 bucks...so now i got to get new gears again...lol
Mods In Garage
Old March 12th, 2010, 10:26 PM   #8
ajm
Yea explorers,expeditions, f150s, etc can have the 31 spline diff. As for rebuilding one its pretty simple. Pop out the s spring, remove the spider gears, remove the clutches, soak the new clutches in friction modifier then stack them in order/per the directions, reinstall the spider gears, reinstall the s spring and youre good to go.
200 bucks for the auburn sounds like a good deal
Old March 12th, 2010, 10:26 PM   #9
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Yeah what i did was got a brand new cobra 31 spline for like 150 bucks or something. Then the install kit. Reused my gears. New 31 spline axles, and a differential cover (another 100 bucks). If it is a good shop reuse the gears and you should be fine. If not they will whine probably. My gears didn't have that many miles on them.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old March 12th, 2010, 11:26 PM   #10
MATT02GT's Avatar
Ford Racing 8.8" 31 Spline Traction - LOK Limited Slip Differential at AmericanMuscle.com - Free Shipping!
Ford Racing 8.8 in 31 Spline Traction - LOK Limited Slip Differential w/ Carbon Discs at AmericanMuscle.com - Free Shipping!
I found these on am....seem pretty cheap. Any idea why the carbon disc diff is cheaper, I thought this would be the stronger one?
Moser 31 Spline Mustang Axles for 8.8in Rear w/ Studs (99-04 GT, Bullitt, & Mach 1) at AmericanMuscle.com - Free Shipping!
Also the axles are on sale, doesnt seem like a bad setup and itd put me pretty close to my budget
Does the MM discount code work on sale prices? If anyone could could pm the discount code that would be awesome.
Old March 12th, 2010, 11:30 PM   #11
2000 GT
Do the axles have the abs thing on it? Something to double check.
Old March 12th, 2010, 11:32 PM   #12
2000 GT
Its on sale more 28% compared to 10%. And you can find those differentials for cheaper im pretty sure. Same one i got for 150 somewhere.
Old March 12th, 2010, 11:33 PM   #13
ajm
Sounds like a good setup. Dont forget to set about 50 aside for some good fluid and black rtv. Youll need 2 quarts 4 oz of fluid...so 3 quarts which will run you 10-15 a quart. Or if youre really tight on money get 2 quarts of fluid that does not have friction modifier in it and 4 oz of friction modifier and youll be good to go.
If that is pushing you close to your budget check latemodelrestoration.com the axles are about $5-10 less, the diff with carbon is about $15 less, and the diff w/ regular is about $50 less. Always funny how everyone is swingin on americanmuscle but half the time their prices are higher.
Old March 12th, 2010, 11:33 PM   #14
2000 GT
First thing on search. Buy Ford Racing Parts - 8.8 inch 31 Spline Traction-Lok Differential
Old March 12th, 2010, 11:34 PM   #15
2000 GT
Yeah, although free shipping! Some stuff they have good prices on, others (like this) you can find elsewhere.
Old March 12th, 2010, 11:36 PM   #16
2000 GT
Speed Concepts - M-4204-F318C - Ford Racing V8 T-Lock for 1979-2008 8.8 31 Spline Mustang GT/Bullitt/Mach1/Cobra/GT500 (with carbon fiber clutches) one for 209 (the website i got mine for 150), but they sold out of those. Hell i had to wait like 4 months on backorder for mine.
Old March 12th, 2010, 11:41 PM   #17
MATT02GT's Avatar
I guess I got some more looking around to do lol
Old March 12th, 2010, 11:51 PM   #18
True, but then you have to figure in the shipping, because it's not always free on every other performance website.
2001 Bullitt #5069
Old March 13th, 2010, 12:02 AM   #19
ajm
Really???? I thought everyone had free shipping?
lets see here. He buys axles and either diff from lmr. He saves 25-65, pays 15 to ship, and still saves 10-50 in the end. Yes you have a point. But even if you do have to pay shipping else where depending on the situation it still may be cheaper in the end.
Old March 13th, 2010, 12:13 AM   #20
2000 GT
Yeah shop around. I always check like 10 sites before i dial down and get what i was going for. LMR is a good one. I usually get stuff from there. And shipping isn't that ridiculous for parts as you would think, they get good discounts. If we shipped same item it would cost 4x more.
Threads Similar to: Rear End
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 04:59 PM
Rear End / Rear Wheels problems caliboss281 99-04 21 January 28th, 2009 05:52 PM
rear disk brakes and rear end extropy Classic Mustangs 3 August 11th, 2008 07:41 PM
rear end patwrecked 5.0 Mustangs 2 February 28th, 2007 11:41 AM
