What size pipe is the vortech discharge pipe
Hey what size is the outlet pipe where it meets the throttle body? I want to grab a coupler I know will fit a 75mm tb
![]() 375hp 380tq Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper vids http://www.youtube.com/user/01mggt Mineral Grey Club member #14 Military Crew E-4 Predator Crew Chief Holloman |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
I wanna say 2.75 but could be wrong as ive never used one. Just saying that considering the discharge on the headunit its self is 2.75. I doubt its any larger than 3" though.
Cool bud. I'll see if anyone else chimes in. The pic online looks like the tb end of the pipe is smaller
This doesnt sound right...so if it isnt dont hold it against me but from what I just found/read on superchargersonline.com it seems like its 2 inches
.Says the discharge kit comes with # 3" x 2" Sleeve # 2-3/4" x 2" Sleeve SuperchargersOnline.com :: Product: Vortech Discharge Assembly for 1996-2004 Ford Mustang GT with 4.6L (Satin) |
I saw That. I wonder if the 2 3/4 is the pipe side and the 2 inches is for the stock size tb?
the 2.75 x 2 would be for the discharge/outlet on the headunit. 2.75 on the headunit then 2 on the discharge
then the other would be 2 on the pipe side and 3 on the tb side as you can still clamp a 3" coupler down onto the factory tb w/o any issues as long as youre using a good clamp |
Moderator
2010 mustang gt auto
your making it hard on yourself. t/b's o/d are all the same it's the i/d thats diffrent (ie. 65mm,70mm,75mm,etc).
MM BRACKET RACING CREW CO-FOUNDER BAMA Performance Drag Team Founder 2010 GT auto
So I should have no issues with my 75 mm? One guy was saying he almost never got the coupler over his 70mm. I can barely get my stock tube on my 75mm
if you do boil the coupler in some water to expand it. I wouldnt worry about it/make it anything to stress about though.
Moderator
shouldn't have any problems. might be tight but thats a feature of the coupler not the t/b.
Moderator
+1^.
Cool I will try that when it gets here. I highly doubt my trickflow tb is exactly the same od as my stocker. The factory intake tube was a biotch to get on there
Just a little trick for what you put it together. Steal some of the womans hair spray and spray down the pipe and couplers with it then slip them together. Itll help the couplers/pipe slide together at first then once it dries itll help hold them together/make a seal along with the clamps. Kinda a 2 for 1 thing.
no way is the piping 2 inches. my procharger's is 3 inches and i didn't see a noticeable difference between the two.
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
#15 | |
"Slide the 3" sleeve and __ clamp onto the throttle body, slide the 2.75" sleeve and __ clamp onto the supercharger discharge." Then the next step or 2 is to install the discharge pipe. Under the parts list for discharge parts it also shows 3" x 2" and 2.75" x 2" for the couplers just as superchargersonline.com does. So I guess the discharge is indeed 2" .
Threads Similar to: What size pipe is the vortech discharge pipe
| oil in the discharge pipe | 1LOUDGT | 2005 - 2010 | 2 | April 30th, 2009 11:01 PM |
| piecing together a procharger-discharge pipe question | SilverStang03 | 99-04 | 3 | October 3rd, 2008 02:40 PM |
| procharger with vortech or paxton discharge pipe??? | SilverStang03 | 99-04 | 0 | September 15th, 2008 03:03 PM |
