Timing a 4.6
Old March 14th, 2010, 08:20 PM   #1
mystang0673's Avatar
6.82@100mph 1.45 60'
mystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura aboutmystang0673 has a spectacular aura about
Timing a 4.6
Can a 4.6 sohc be timed without having to take the heads off? i have already put my heads back on my engine. a friend is supposed to come time it up for me but i was reading on how to do it myself. The only info i got was on modulardepot and the way it says it, you have to have the heads off to find out what position is "safe mode". Can any of you guys point me in the right direction of some more info on timing a sohc motor or tell me how. lol
Old March 14th, 2010, 08:31 PM   #2
ajm
Look at the front cover. Youll see a stamping that says TDC kinda shaped like a box with an arrow at the bottom end. Its at about the 10-11 o clock position on the front cover. Look at the back edge of the crank pulley and youll see a notch/slot cut in it. Line that notch up with the TDC mark on the front cover. Rotate it 45* counter clock wise and that is "safe mode".
Old March 14th, 2010, 09:01 PM   #3
Garhfer's Avatar
2004 Mustang GT Conv.
Garhfer is on a distinguished road
Send a message via AIM to Garhfer
Timing the 4.6L SOHC Engine
2004 GT Boosted by Vortech
Old March 14th, 2010, 09:29 PM   #4
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
If keyway on crank is at 9:00, its in safe mode.
Old March 14th, 2010, 09:37 PM   #5
BakerFX4's Avatar
iTrader: 14 reviews
ajm.... are we saying the same thing? Ive never looked at the timing cover. With my timing cover off and heads on.... This is what i did....
Put keyway on crank at 9:00 (all pistons are down in the block)
Put my cam dots at give or take 11:00 on both heads (will have to adjust accordingly)
Laid chains out and dot the ends with fingernail polish
Put one of the chains ends on the crank mark (will be a groove at about 5 or 6:00) and the other end on the dot of the cam gear.
Do the driver side first then the passenger. I had all my cams bolted down and just turned them with a ratchet/socket to where they needed to be to line my marks up. passenger side is slightly more tricky.
I PM'd you too.
Old March 14th, 2010, 09:44 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
lastly... turn the motor over a few times to be sure you arent hitting anything.
Old March 14th, 2010, 10:21 PM   #7
ajm
Yea, same thing. Just 2 different ways to go about doing it. the tdc then 45* clockwise was just the first that came to mind when I posted.
Old March 14th, 2010, 10:22 PM   #8
BakerFX4's Avatar
iTrader: 14 reviews
k cool! yeah its an easy task for sure.
Threads Similar to: Timing a 4.6
Timing??? flamed 98 gt 5.0 Mustangs 1 February 7th, 2009 12:55 AM
Timing sctravis77 Classic Mustangs 5 January 26th, 2009 09:37 AM
timing SleeperStang88 V6 Mustangs 7 November 29th, 2008 02:11 AM
timing B.A.M302 5.0 Mustangs 4 April 8th, 2007 06:36 PM
