tapping oil pan?
alright so ive been thinking when i get my supercharger i dont want to tap the oil pan(ik ik get a procharger lol) but i about to get my hands on a novi 2000 so what would be the best way if possible to bring the car somewhere to get that done? can i put everything with no belts and just drive it down there??
2002 mustang gt
Na
It not that bad just buy the punch from supercharger online
2003 Mustang GT
1/8 - 8.09 @ 91.39mph 1/4 - 12.35 @ 114.52mph
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 11 reviews
To be honest man, its very easy. But dont over tighten the brass, it will strip.
I bought the 3/8 NPT Punch, and took a hammer and kept tapping it in there, it went in very easy.
![]() 2003 Mustang GT Vortech V1 Intercooled SAE Corrected - 380rwhp & 380rwtq @ 9psi Uncorrected - 401rwhp & 400rwtq @ 9psi Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
Yea I hear ya but if I don't do it can I just puteverything on without the belt and drive down there
I wouldn't recommend that since you are going to have to swap your pullies around to install it. Just tap it yourself. If you are afraid of punching the hole too big just tap the punch in a little bit at a time and then pull it out and check it with the tap. That's how I did it to make sure I didn't make the hole to big and it's worked for me...twice! I installed the same blower on two Bullitts.
Blown 03 GT
I didnt even use a tap, just a conical drill bit then taped the hole. Did my car and my buddies like that and it worked great.
Black what pullies are you talking about?? I could see the idler pulley possibly getting in the way but that would be easy enough to swap out. Call your tuner you may be able to arrange to have them tap the pan for you and install the belt and anythin else you may need. Honestly though its not very hard, try and find someone local to help you out.
If the paxton setup is anything like the Vortech you have to take one idler pulley off and add it to the blower bracket and in the idler pulley's original place goes a grooved idler pulley from Vortech. So, that makes it difficult to use the stock belt in the new configurations. I'm pretty sure the two brands or similar in installation, but I'd have to view an installation guide off their websites.
2002 mustang gt
Na
If you live a town away from me were are going with it
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
Buy a 3/8 npt tap for a few bucks and the punch from superchargersonline.com for 20 something bucks. Mark the correct spot per the manual. Hammer the punch in to the correct depth, then tap it....Simple as that other than packing the tap with grease and applying black rtv. Only way youre gonna screw it up is if youre an absolute dumbass. Last edited by ajm; March 16th, 2010 at 06:40 PM. |
Yahtzee
#11 | |
not sure yet i was thinking either EFI Logic, J&M Motorsports in CT or DEZ in mass for the tuning .. and for the taping of the pan i wasnt sure yet but ill probably try it myself
2002 mustang gt
Na
Chris tune my lightning from efi and that where I'm going
After you tap the pan clean the threads in the pan and threads on the brass fitting with lacquer thinner. Apply black rtv to both threads. Thread the brass part in. Then smear black rtv around the outside of the brass fitting where it butts up against the pan. Thatll settle your worries about leaks
2002 mustang gt
Na
Ajm I right but I also sand around the hole to take the paint off to make sure I seal right and after I will hit it with black paint
02 Mustang GT
9.91@133
Take your pan off and have someone weld a bung on it. I have a stock oil pan with two 1/2 npt bungs welded in the front the front. I have a "7" quart pan I run now.
2002 GT PI heads Twin 60mm turbos Th400 6.34@114 1/8 9.99@137 1/4 http://i160.photobucket.com/albums/t...t/DSCF5654.jpg http://i160.photobucket.com/albums/t...2gt/IMG060.jpg |
2003 Mustang GT
Go to Dez man. Dez is the best at what he does...Call him and talk to him. Im sure hed send u a base tune. Plus his prices are great.
Alright sounds good but I don't have a tuner for a base tune to be loaded onto anything else I could do
Just remembered I don't have a tuner so I'm gonna have to have it towed to the tuner anyways
Threads Similar to: tapping oil pan?
| Oil Pan | Cool Bam | 2.3 Mustangs | 2 | July 9th, 2009 09:29 PM |
| Oil Pan | 91 gt 5.0 | 5.0 Mustangs | 3 | March 25th, 2008 12:06 AM |
| Oil Pan | 95kystang | V6 Mustangs | 12 | October 9th, 2007 12:37 AM |
| kickout 7qt oil pan w/low oil sensor hole | Iownastang | 5.0 Mustangs | 2 | July 19th, 2007 02:17 AM |
| Oil Pan | Pony_with_an_attitude | 5.0 Mustangs | 3 | March 5th, 2007 08:40 PM |
