still breaking up
Old March 16th, 2010, 01:10 PM   #1
damon4192's Avatar
2001 mustang gt & 86 gt
9.84(86stang)
damon4192 is on a distinguished road
still breaking up
hey guys i got a 2001 mustang gt and my car was breaking up so i was told to replace the fuel filter. its only breaking up in the high rpms. and when im punching it. i have no clue what it is. could it be plugs and wires? the only thing i can think of was that i was close to empty and on a hill and that the gas was flowing to one side of the tank and making it seem like there was no gas in it. its done it once on the highway before but i cant remember if i was on E or not. im lost. any help would be great, thanks
White Mustang Crew Member #8
2001 white mustang gt- exhaust, intake, 96k
1986 mustang-shootin for 9.8 this year, will have vids soon
Old March 16th, 2010, 01:53 PM   #2
ModularSteed's Avatar
1997 Mustang GT
335rwhp/370rwtq
ModularSteed is on a distinguished road
start with plugs and wires
97 GT|Full PI Swap|BBK UDP|C&L Upper Plenum|Flowmaster Exhaust|O/R H|3:73|B&M|SCT X3|NOS 75|Eibach Pro Kit|99 SVT Wheels|
Originally Posted by 330CubeGt View Post
On a serious note i would try some vasoline and is should wiggle right in.
Old March 16th, 2010, 02:50 PM   #3
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
01's don't have plug wires, but I would replace the plugs first
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old March 16th, 2010, 07:52 PM   #4
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
No plug wires? At all?
I know you have coil packs, but I was under the impression there were still wires.
Its most likely your wires or coil packs. Mine used to do the same thing. Only under load at higher RPM's right? If you rev it while you aren't moving, it doesn't do it? That is the electrical system.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old March 16th, 2010, 10:18 PM   #5
damon4192's Avatar
9.84(86stang)
yeah. it only when it is full throttle in the high rpms. starting to do it when i cruise now to.
Old March 16th, 2010, 11:39 PM   #6
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
If the car was low on gas then the car might be surging just b/c there is no gas and 99-04 GTs do not have sumped tanks so the fuel sloshes around. Try filling the car with gas and then try to replicate the problem again. If you are still having a problem then I would do plugs, which are cheap, and also a fuel filter, which is also cheap. When doing the fuel filter make sure you buy the fuel line disconnect tool, you have to have it in order to remove the filter. Also check to make sure you don't have any water around the coil boots.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old March 17th, 2010, 01:37 PM   #7
damon4192's Avatar
9.84(86stang)
hey thanks for the info i did fill the tank after and it worked. but i already replaced the fuel filter and that tool info would have deff came in handy being that i had to go buy one lol thanks tho and i am considering changing the coil packs next to be safe. thanks
Old March 17th, 2010, 03:00 PM   #8
1999 GT
iTrader: 7 reviews
Sounds good man
Threads Similar to: still breaking up
01 gt breaking up damon4192 99-04 21 March 10th, 2010 01:34 PM
Breaking up..... WAR-PARTY The Clubhouse 17 November 17th, 2009 11:28 PM
Breaking in a sub Big C Audio/Video 15 October 17th, 2009 03:34 PM
Breaking Out! Dansby The Clubhouse 5 March 2nd, 2008 04:53 AM
Under Breaking... jessy_is_rad V6 Mustangs 4 October 10th, 2006 12:31 AM
