Help!
soo last weekend i changed my intake manifold gaskets and pretty much did a complete tune up on the car as well. Everything was running great the whole week until i spotted a coolant on the garage floor yesterday. I checked all around the heads and nothing is leaking there like it did before i changed the gaskets and there are no leaks in the hoses. I drained my oil just to check if by some chance coolant was again leaking in but it was clean. Any ideas as to where this coolant could be leaking from?
00GT-SLP LM2's, Pypes x-pipe, BBK CAI, MGW short throw shifter, Centerforce DF Clutch, KYB Shocks and Struts..coming soon SCT XCAL3, 70mm throttle body, and Plenum |
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
where was the coolant..under the engine or more in front?
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone 4V swap in the works |
towards the front of the engine, i checked the drain spout on the radiator too just to make sure i wasnt going crazy lol and it was closed
BYAHHHH!
2001 Mustang GT
13.874
check the overflow tank tube under it too
check the heater hose in the back i had that problem and it drained coolant all the way to the front of my engine
LED third brake light to replace old sun damaged one, shorty antenna, new PI Intake Manifold with aluminum crossover (my original was all plastic). Bosch Platinum 4 Spark plugs (awesome set)
heater hose is tight and not leaking...it can see some coolant running along the engine block and dripping down to the sway bar but thats it
thats weird mine did the exact same thing you sure no where near the area of the heater hose is leaking ?
2000 mustang GT
what about the line that runs under the intake, maybe you hit it loose or something
it was the water pump, i cant believe it took me that long to see finally see it but at least its something simple lol
good to hear!
