Oil with vortech
Old March 16th, 2010, 06:40 PM   #1
2002 mustang gt
Na
Jaygt is on a distinguished road
Oil with vortech
So I just installed my charger and the only thing left is to change my oil. So what are you running . Should I run mobile one 5 20 or somthing differant
Old March 16th, 2010, 06:45 PM   #2
ajm
Oh boy this should get interesting quick....Run whatever oil you like best. Personally I run 5qts 5w20 valvoline synpower and 1qt 5w30 of the same stuff. Add 5 qts and check the dip stick, continue to add little by little until it shows full.
Check out bobistheoilguy.com if youre looking for some good oil info. Not just "Mobil1 ftmfw, use royal purple its the best,etc,etc".
Old March 16th, 2010, 06:50 PM   #3
Black Bullitt's Avatar
2001 Mustang Bullitt
Faster than Twinmill
Black Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really niceBlack Bullitt is just really nice
Send a message via AIM to Black Bullitt
I use full synthetic 5w20.
2001 Bullitt #5069
505rwhp/538rwtq @ 15#s
Originally Posted by FluffyTheRhino View Post
Nothing says "Upgrade EVERYTHING" like busted parts
Old March 16th, 2010, 06:50 PM   #4
2002 mustang gt
Na
Is royal purple realy what it crack up to be
Old March 16th, 2010, 06:52 PM   #5
Supposedly there are results on the web somewhere showing an actual gain by using royal purple. I think the results were minimal. I've never gone searching for it as I honestly don't care if I gain another 10 hp from oil. It's not worth the price IMO.
2001 Bullitt #5069
Old March 16th, 2010, 06:54 PM   #6
blk35th's Avatar
1999 Mustang GT
Before(12.80@104) Still have to get a new time after biuld
blk35th is on a distinguished road
I use regular non synthetic as advised by my technician whom also has had his share of vortech biulds. Motorcraft or Mobil 1. Nothing else other than either of those. 5 30w
Old March 16th, 2010, 07:04 PM   #7
Your egnine, your supercharger, but synthectics are more thermally stable for the amount of heat blowers generate over your conventional oil. Don't take my word for it, becaause I'm not a technician. (enter sarcasm)
2001 Bullitt #5069
Old March 16th, 2010, 07:08 PM   #8
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
I use 6qts of Mobil 1 every time
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old March 16th, 2010, 08:59 PM   #9
ajm
. From what ive come across showing technical data..not just I use ___ its the best. Redline works extremely well in high heat apps.
As for the guy asking about royal purple I donno. Ive used it and wasnt too impressed but thats just my opinion. So far ive had the best results with the valvoline synpower.
Old May 5th, 2010, 11:30 PM   #10
2001 Mustang GT
realrider88 can only hope to improve
What would be best for being FI? what weight? i got a windor which should have six quarts of 530
Old May 5th, 2010, 11:43 PM   #11
1999 Mustang GT
hardhitter has a spectacular aura abouthardhitter has a spectacular aura abouthardhitter has a spectacular aura about
Send a message via AIM to hardhitter
Vortech recommends synthetic 5w30 or high grade SH/CF rated oil.
Vortech V2 Si
Old May 6th, 2010, 03:20 AM   #12
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
I was recommended 5w30 valvoline dino by MPH and Proline (the guys who built my engine) for use with a blower setup.
Honestly, you will be fine running pretty much anything either 5w30 or 5w20 as long as you aren't changing back and forth all the time between synthetic and dino and you are changing it regularly.
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Threads Similar to: Oil with vortech
how many oil seals does a vortech have? hardhitter 99-04 0 January 20th, 2010 09:22 PM
vortech oil seals hardhitter 99-04 3 August 26th, 2009 09:59 PM
vortech oil drain fitting ajm 99-04 7 February 24th, 2009 11:07 AM
Oil Change with the new Vortech MeZ 99-04 1 April 15th, 2008 01:01 PM
What oil to run on a vortech supercharger?? bossman2kgt 99-04 7 June 24th, 2007 05:44 PM
