Auto Transmission
Old March 16th, 2010, 07:32 PM   #1
trent2590's Avatar
trent2590 is on a distinguished road
Auto Transmission
I looked and could not find anything so if someone else finds a thread that has to do with my issue please post it.
I know that 2000 gt's have a T-45 tranny but what about automatics i know its different just not which one also there are so many products out there i dont know which to choose for instance what brand of tranny filter should i buy and where is it located when I change it?
what kind of kit am i looking for as far as replacing gaskets?
and would lucas tranny fluid additive be a good idea
I was also told to turn the engine how is that done once i take the transmission pan off so that i can get to the bolt to take the fluid out of the torque box?
thx for the help sorry if iam being annoying im just a little worried that the fluid has never been changed because of the sounds that its making.
LED third brake light to replace old sun damaged one, shorty antenna, new PI Intake Manifold with aluminum crossover (my original was all plastic). Bosch Platinum 4 Spark plugs (awesome set)
Old March 16th, 2010, 07:55 PM   #2
El Danno
dcook_14's Avatar
12.35@114.08 w/ 1.88 60'
dcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to beholddcook_14 is a splendid one to behold
iTrader: 7 reviews
4r70w
DCook garage sale is on!
Originally Posted by mrsinister2424 View Post
And I roll up with my retarded exhaust setting off car alarms and wetting panties for miles
Originally Posted by sharkbait View Post
I do like that nasty.
Old March 16th, 2010, 08:16 PM   #3
trent2590's Avatar
whats tht?
Old March 16th, 2010, 09:03 PM   #4
ajm
You have a 4r70w not a t45. Get an oem or purolator (sp?) filter. The pan gasket is reusable. I wouldnt go sticking anything other than mercon v in there but thats just me. And I was the one that told you about draining the torque converter. Yes. Remove the cover to the access hole, turn the car over by hand and look in the hole with a light until you see a small drain plug.
Old March 16th, 2010, 09:20 PM   #5
El Danno
dcook_14's Avatar
iTrader: 7 reviews
Originally Posted by trent2590 View Post
whats tht?
It's what your transmission is.
Your first post was kinda garbled and didn't have any punctuation in it so I didn't read it through. AJM kinda nailed it though. OEM filter, reuse gasket, mercon V fluid...
Old March 16th, 2010, 11:10 PM   #6
trent2590's Avatar
Thx guys so is my transmission a tremec brand tranny?
Old March 16th, 2010, 11:12 PM   #7
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
no sir
4V swap in the works
Old March 17th, 2010, 12:02 AM   #8
Moderator
casper gt's Avatar
2010 mustang gt auto
casper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud ofcasper gt has much to be proud of
+1^
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2010 GT auto
Old March 17th, 2010, 05:45 PM   #9
trent2590's Avatar
another quick question should i pour the fluid through the shifter or the designated place in the engine bay?
Old March 17th, 2010, 07:00 PM   #10
BYAHHHH!
2001 Mustang GT
13.874
engine bay...back pass. corner
Old March 17th, 2010, 07:24 PM   #11
trent2590's Avatar
thx
Old March 17th, 2010, 07:25 PM   #12
BYAHHHH!
2001 Mustang GT
13.874
np man
Old March 18th, 2010, 06:12 PM   #13
trent2590's Avatar
another question on the transmission fluid change
Ok so I just went to the Ford parts store and purchased 4qts of mercon v (and a filter) because I need 3.3.
So I went to the counter and the guy asked me if I needed 15qts. So my question is do I need to buy more to change the fluid because I thought I only needed roughly 4qts?
P.S. does the engine have to be in neutral to turn it?
Old March 18th, 2010, 10:58 PM   #14
trent2590's Avatar
really need help so that i know exactly how much and dont break sumthn
thx!
Old March 18th, 2010, 10:59 PM   #15
ajm
Im all for doing it yourself etc but I really think you should just take it somewhere and have it done.
On the other hand if you just drop the pan, change the filter, bolt the pan back up, and refill youre looking at 3-4 qts if I remember right. Ive never just dropped the pan and replaced with xxx amount (keep reading for why). If you drain the torque converter youre gonna need quite a bit more. No exact amount given because you dont know how much was exactly drained and you dont want to be too high or too low with your trans. Best way to do it is add x amount. Check the stick. Add more, check the stick, and repeat the process, while the fluid is hot/warmed up until youre in the correct range.
Old March 18th, 2010, 11:55 PM   #16
trent2590's Avatar
well it costs alot to not do it yourself like 150+
Old March 19th, 2010, 12:09 AM   #17
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
im also for doing it yourself but i think taking it to a shop would be best this time. Its not something you want to risk not doing right. It shouldnt be 150 bucks.
Old March 19th, 2010, 12:16 AM   #18
Moderator
casper gt's Avatar
I'd go with the 15 qt.'s if your draining the converter.
2010 GT auto
Old June 3rd, 2010, 01:52 PM   #19
mustangmike!'s Avatar
2004,1994,1967
14.37 @ 96
mustangmike! has a spectacular aura aboutmustangmike! has a spectacular aura aboutmustangmike! has a spectacular aura about
im just curious as to how this turned out
FUCKING AWESOME: http://www.youtube.com/watch?feature...&v=Te0V71sGoxA
Purple Haze
Old June 3rd, 2010, 05:50 PM   #20
trent2590's Avatar
lol i didnt end up doing anything about it haha
Threads Similar to: Auto Transmission
Auto Transmission USMC '03 GT 99-04 13 September 15th, 2009 04:06 AM
Transmission flush - 05 Auto fatalflaw 2005 - 2010 V6 6 August 18th, 2009 06:54 PM
92 lx 5.0 Transmission Auto bob 5.0 Mustangs 0 September 28th, 2008 09:08 PM
65 mustang auto transmission stalker Classic Mustangs 10 September 26th, 2008 07:59 PM
Auto transmission removal please help me Stang6899 V6 Mustangs 9 January 1st, 2008 10:52 AM
