Ticking noise!! Please listen and give me your input!!!
Old March 16th, 2010, 07:47 PM   #1
jrfan4life's Avatar
2001 Mustang GT
NA
jrfan4life is on a distinguished road
Ok... So I had a misfire in cylinder #1 so I changed out the COP and misfire went away but I have a ticking now that I an worried about! There dosent seem to be any loss of power or anything. I thought it was the tensioner but I realy dont know.. Please listen and tell me what u think> Attached is the video I took... I know my engine is dirty.. Just took it out of storage>.. Alaso... The oil is at the right level...
I didnt know witch link would work so I posted them all...
Old March 16th, 2010, 07:57 PM   #2
mrsinister2424's Avatar
99' Mustang GT
3214@OVER 9000!!!
mrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to beholdmrsinister2424 is a splendid one to behold
Send a message via AIM to mrsinister2424 Send a message via MSN to mrsinister2424
Yikes. Does it increase with rpm? Does it sound like an exhaust leak? Sounds like metal tapping or some shit. Doubt its the tensioner but it would take only a couple mins to find out.
99' Rio Red Mustang GT: --My Garage--
Check garage.
Vortech V-1 intercooled running 9lbs of boost
Life= eat, lift, eat, eat, eat, sleep, repeat
Old March 16th, 2010, 08:51 PM   #3
Mizark347's Avatar
Mizark347 will become famous soon enough
Hard to tell from the video, but sounds like an exhaust leak to me. Put your hand down by the passesnger side header while the engine is cool and see if you feel anything.
2002 Oxford White GT
Procharger P-1SC@9PSI, Comp Cam 270's
431rwhp 413 ft/lbs
Old March 16th, 2010, 09:25 PM   #4
jrfan4life's Avatar
2001 Mustang GT
NA
Its definatly not an exhaust leak..... Yes it does increase with RPM's
Old March 16th, 2010, 09:54 PM   #5
jrfan4life's Avatar
2001 Mustang GT
NA
Bump whore....... Come on guys...... gimme some smats.....
Old March 16th, 2010, 09:59 PM   #6
y2k02's Avatar
02 Mustang GT
9.91@133
y2k02 has a spectacular aura abouty2k02 has a spectacular aura abouty2k02 has a spectacular aura about
bent valve stem
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
http://i160.photobucket.com/albums/t...t/DSCF5654.jpg
http://i160.photobucket.com/albums/t...2gt/IMG060.jpg
Old March 16th, 2010, 10:22 PM   #7
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
I second the valve stem, if it were bottom end I would say a rod bearing because there seems to be a new thread about them every day lol. Time to tear the heads down and check everything out. If it's not there, you gotta pull the timing cover and inspect there. My friends mustangs do this too, and they all sound like they are coming from different spots. My old motor used to make a light tick but it was never that loud or caused any problems, check out everything you can but unless you experience problems, I wouldn't worry about it cause everyone seems to have a "tick" of some sort lol.
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old March 16th, 2010, 10:31 PM   #8
jrfan4life's Avatar
2001 Mustang GT
NA
If it's a bent valve stem do u think it's ok to drive? What kind of longevity we talking about?
Old March 16th, 2010, 10:46 PM   #9
Steelsoldi3r is on a distinguished road
its hard to hear but check your bearings in your motor, rods
3.55 gears, Cai, magnaflow exhaust, advanced timing to 12 degrees,underdrive pullies, throttle body spacer, plenum intake spacer, BBK o/r H-pipe, king cobra clutch....havent gone to the dyno, more to come
Old March 16th, 2010, 11:20 PM   #10
y2k02's Avatar
02 Mustang GT
9.91@133
What mine sounded like.
2002 GT
PI heads
Twin 60mm turbos
Th400
6.34@114 1/8
9.99@137 1/4
Old March 17th, 2010, 04:04 AM   #11
jrfan4life's Avatar
2001 Mustang GT
NA
Bump whore$@&€£
Old March 17th, 2010, 04:39 AM   #12
jrfan4life's Avatar
2001 Mustang GT
NA
So what was causing the ticking in yours? Did u fix it?
Old March 17th, 2010, 05:45 AM   #13
ITS ME DAVID's Avatar
ITS ME DAVID is on a distinguished road
Could need Valve adjustment or bent valve.
please Visit MyYouTube Profile Below
http://www.youtube.com/adjmproduction
Old March 17th, 2010, 07:15 PM   #14
jonwrong's Avatar
2000 Mustang GT Super'ed
jonwrong will become famous soon enough
Compression test the thing if you are concerned about a bent valve. Easy enough to see if that's possible with low compression.
Old March 17th, 2010, 08:38 PM   #15
jrfan4life's Avatar
2001 Mustang GT
NA
Ok... Took it to a motor builder in town and the sound is the timing chain slapping on the cover. The guides are worn or broken. So wee going to take it apart and replace the chains, guides, and gears... Anyone recomend a brand for this set up? I wana purchase the whole kit.
Old March 17th, 2010, 08:54 PM   #16
jrfan4life's Avatar
2001 Mustang GT
NA
Found this kit... My car is vin code X, 2001 GT
FORD TIMING CHAIN KIT MUSTANG GT 4.6 281 X SOHC 01-04 : eBay Motors (item 120478569895 end time Apr-07-10 00:42:03 PDT)
Old March 17th, 2010, 09:48 PM   #17
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to allmrbigjeep is a name known to all
wow and i thought i had a very light ticking...mine is NOTHING compared to that! lol now that i've heard that i don't even think its the motor. probably just my injectors or something
cams + 150 shot
Threads Similar to: Ticking noise!! Please listen and give me your input!!!
a ticking noise 87gtmustang 5.0 Mustangs 20 February 7th, 2009 02:43 PM
Ticking Noise? 99Rumblebee V6 Mustangs 3 September 27th, 2008 01:08 AM
07 v6 radiator help please give input 97gtstang General Tech 0 July 25th, 2008 07:24 AM
anyone wanna give input? Dennis The Clubhouse 3 June 9th, 2008 11:56 PM
ticking noise tweeters97 96-98 2 March 16th, 2008 10:31 PM
