compression
Old March 6th, 2007, 10:45 AM   #1
greenstallion is on a distinguished road
compression
is 10:5.1 to much for a 2000 gt
2000 gt bbk c/a, trick flow plenum, bbk 75mm t/b, bbk pulleys, bbk o/r x-pipe, b&m shifter, 40series flowmasters, motive 4.10s
Soon long tubes, stage 2 heads and stage 2 cams, forged bottem end
Old March 7th, 2007, 09:56 PM   #2
giannisal8's Avatar
07 Roush/07 GT/98 Cobra +
giannisal8 is on a distinguished road
Send a message via Yahoo to giannisal8
NOT REALY. QUESTION IS WHAT DO YOU WANT TO DO WITH THE CAR EVERY DAY STREET OR JUST RACE
REMEMBER GAS IS EXPENSIVE
IF YOU WANT TO BUILD A MOTOR PUT IT ON PAPER AND SEE IF EVERYTHING WILL WORK TOGETHER. YOU KNOW WHAT HEADS YOU WANT, CALL THE MANUFACTURE AND SPEAK WITH A TECH, THEY WILL BE ABLE TO GIVE YOU A COMBINATION THAT WILL WORK , CAM AND PISTONS THAT WORKS GOOD WITH THERE HEADS
Old March 8th, 2007, 01:07 AM   #3
sleepinggt is on a distinguished road
10.5 is fine, many people do a PI swap that alone gives them that much CR and i've seen a few people swap in a 96-01 cobra shortblock on PI heads that yields nearly 12:1
Old March 8th, 2007, 02:39 AM   #4
matrixpuba is on a distinguished road
Send a message via AIM to matrixpuba Send a message via MSN to matrixpuba Send a message via Yahoo to matrixpuba
it will be fine. if anything if you get crappy gas where you live and get spark knock you can always pull a little timing to get rid of it.
Old March 8th, 2007, 06:40 PM   #5
WAR-PARTY's Avatar
2001 YUGO GT
WAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of lightWAR-PARTY is a glorious beacon of light
10.5 // 11.0 ratios are fine with high test gas. back in the day 11 to one was standard on many hig performanc OEM engines. BUt if you are thinking of adding a supercharger this is was to much you waant an 8.0 to ration if ya go the route. High compression engines do have a nice tight sound to them.
Threads Similar to: compression
compression 9 to 1 VS. 11 to 1 ryanw 5.0 Mustangs 6 November 13th, 2010 09:18 AM
Compression mustangmanic 99-04 12 October 10th, 2007 10:01 PM
compression? matfernan1 99-04 5 August 30th, 2007 11:42 PM
Compression Clockman 94-95 3 May 4th, 2007 03:16 PM
compression greenstallion General Tech 2 March 6th, 2007 11:24 AM
