#61 |
![]() iTrader: 1 reviews
Ysi's are badass I have a vid on YouTube of a fox I saw at a dyno day that had a built bottom end 331,edelbrock victor heads,victor efi intake,all supporting mods and a ysi and it put down 775 at 6500 and sounded amazing doing it.
79 Buick regal 13.70 @102 350 sbc 97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir 04 SRT-4 13.42@113.55 2.37 60ft ![]() 04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot 06 Mustang GT 12.2929@114.30 2.01 60ft MM Bracket Racing Crew Member #4 |
#62 |
R.I.P.
twin screwed!!
![]() ![]() ![]() iTrader: 9 reviews
since were spitting out psi number's and setups...
i'm making about 12.5 with a cx kit and 2.8 pulley with an anderson power pipe...figure in a 3psi pressure drop should be about right... i really think the cx coolers are a bit much for a supercharged application under 10psi , the core is huge and would be more suited for something upwards 17+.. i'm actually thinking i may go smaller, just to make some more boost..
#63 | |
I made same boost numbers you were when I had same pulley and intake setup on stock heads. Put out 515 rwhp.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS. ![]() NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES! TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
#64 | |
12.35 @ 116
#65 | |
R.I.P.
twin screwed!!
as far as measurements it's the same ic you got..
#66 | ||
With a built bottom end and a completely stock upper end including exhaut manifolds I made 431 with a 2.8" RR SC pulley the 31x12x3" ic, and a V1. So my compression was slightly lower than stock and forged bottom end is heavier also, but I'm sure it was much better balanced engine. Plus the tuner can run a little more timing on a built sb. But I was running Houston performance S292 blower cams and a nice well balanced short block built my MMR. My power mods @515twhp were V1 S-trim at 12.5-13 psi. Stock crank pulley and a 2.8" RR SC pulley AFM power pipe Stock intake and heads including stock valve springs HP s292 cams not degreed dropped in with a AFM cam retention tool Mac LT's Mac h pipe Mac cat back Professional Products 75mm TB/Plenum Cheapest 31x12x3" IC I could find 4 years ago. Looks just like the CRX 31x12x4" I run now but thinner of course. An universal piping kit. Support mods. (fuel mods, tune, etc)
#67 |
R.I.P.
twin screwed!!
i pretty much have all that and then some, just no cams...and a fat tune...
#68 | |
Cams and lt's alone gave me over 84 rwhp.
#69 |
R.I.P.
twin screwed!!
one of these days i'll get cams....seems to help fi big time..
i see what all you guys are getting with just adding blower cams..maybe this winter..
#70 |
Do you have a forged bottom end? You might want to pulley up a little.
#71 | |
Vortech V2 Si
#72 |
R.I.P.
twin screwed!!
i thought about going to a 2.6, but i was told i will have a harder time with belt slippage issues...bottom end is stock.
about the boost issue, i have no clue...my car's just gay i guess!!
Threads Similar to: Dyno Results
| Some dyno results | Mustang RacR94 | 4V / SVT | 7 | July 29th, 2009 02:25 PM |
| Dyno results | 03SuperchargedGT | 99-04 | 35 | March 4th, 2009 10:12 AM |
| dyno results | 85hatchgt | 5.0 Mustangs | 1 | August 27th, 2008 05:33 PM |
| Dyno Results! | hardhitter | 99-04 | 45 | July 20th, 2008 11:41 PM |
| Dyno Results.. | DarkCandy08GT | 2005 - 2010 | 10 | July 6th, 2008 12:21 PM |
