2003 Mustang GT
1/8 - 8.09 @ 91.39mph 1/4 - 12.35 @ 114.52mph
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 11 reviews
Dyno Results
Hey guys, sorry for being late on this. Well my camera died halfway through the first pull, so sorry. No vids. But to say the least, I was dissapointed.
Vortech V1 headunit, FMIC, 3.33 pulley Made: 340rwhp and 320rwtq...ONLY at 6.1lb of boost. VERY low boost. My tuner told me, the stock Vortech intake really chokes it off. He told me to do a AFM Powerpipe, and re-tune (only $75) and if I want after, do a smaller pulley. The car feels good, its obviously, faster and pulls good. But, 6lb of boost killed me.
![]() 2003 Mustang GT Vortech V1 Intercooled SAE Corrected - 380rwhp & 380rwtq @ 9psi Uncorrected - 401rwhp & 400rwtq @ 9psi Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
![]() iTrader: 1 reviews
Sorry about the dissapointment man. Yeah 6lbs isn't much on any fi setup. Now just throw a 2.9x pulley on and get it retuned. Oh and those are decent numbers so don't feel bad.
79 Buick regal 13.70 @102 350 sbc 97 Trans Am WS6 11.94 @112.26 1.603 60ft @Kcir 04 SRT-4 13.42@113.55 2.37 60ft ![]() 04 Mustang GT 12.19 @111.88 347hp 432tq 100 shot 06 Mustang GT 12.2929@114.30 2.01 60ft MM Bracket Racing Crew Member #4 |
2012 Brembo Mustang GT
Glad to see u finally got the it done...but only 6lbs even with the 3.33 pulley?
That worries since I'll be putting in a similar setup. Did you check for a any leaky couplers?
![]() 01' GT Supercharged and Intercooled....387RWHP - SOLD 2012 Brembo GT
2007 cadillac sts
hey man those are good numbers for 6psi your still pushing a decent ammount for the money you put into the kit. with just a little more you can deff make well above what you have now!
2003 Mustang GT
14.03@100
Do the AFM power pipe. Also try a 3.2-3.0 pulley if you're still low on boost.
2003 Mustang GT
Yea no boost leaks, but Im double checking everything tomorrow. Its accually pretty good power for only 6psi. Im just surprised it was so low.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
nice shaun... smaller pulley would get the job done for sure.
2003 Mustang GT
Thanks baker. He told me the power pipe would definatley let more air flow in, and that the stock vortech intake was the restriction. I hope so, he said typical gains are 2-3lb of boost....is that right? And usually how much rwhp per lb of boost? Like 15?
You could be getting pressure drop through your intercooler. I opted not to get a Powerpipe because I thougt it would add too much boost with a 3.33 pulley...now I may change my mind.
More like 10hp for 1psi. But if you pick up 3psi from just the pipe you might wait to swap pulleys.
to be honest with you, going from the procharger inlet to the AFM, i really didnt notice anything and i wouldnt get it again. I would instead build my own. Ive seen some BADASS ones before that were homemade. It was badass. It was a local guy here that made it. I almost sold mine to make one like his but didnt do it.
Hooo Ha Ha
Can someone explain these power pipe things.
![]() 374rwhp 456rwtq @ 8psi |
2007 cadillac sts
basicly its a bigger intake for the supercharger so it lets more air in
6psi? I had 11psi with the 3.33" pulley and powerpipe
Vortech V2 Si
i have the powerpipe and 3.12 pulley and im making 10psi
![]() RET tuned 718rwhp/588tq |
Hooo Ha Ha
Can someone explain in more depth how they work? Also how would I make one?
ty though 00mustang00 reps givin
IIRC you dynoed at 260 before the vortech. Well if that is so you are making 13.33 rwhp per PSI.
Super Slow 2011 Grabber blue V6...
BYAHHHH!
2001 Mustang GT
13.874
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
not bad man...but 3.33 pulley making 6 psi...something is off. Procharger(i know different) told me a 3.6 should make 10psi but I got the 3.4 just incase.
![]() Precision Turbo|TurboSmart|TeamZ|Strange|Hellion|BBK|SCT|Edge Converters|Fairbanks|CG Fabrications|Treadstone 4V swap in the works |
yeah my stock procharger pulley makes 10psi
2002 Procharged GT 12.503 @ 113.08 351rwhp 353rwtq Car Videos: http://www.youtube.com/user/mell00ut5?feature=mhee
Ebay ic's cool well but are restrictive. An ic that is designed to cool well has to do so by having more fins/surface area for the air to come in contact with so heat can be transfered. I have seen procharger ic's flow better but not cool quit as well than the 2 ebay ic's I have used. Cooler air allows for safer operation (less detonation) and more timing for power. A free flowing IC allows for more boost to the motor but higher temps so a trade off. Plus some head units are less efficent and run hotter than others when pushed.
Plus V1's like we have, have less of a internal step up ratio than the V2 and a lot less than the P1SC/D1SC. So it will take a smaller pulley to see the same boost at the motor than the others.
2000 GT 665/540rwhp/rwtq On pump gas Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S DYNO VID ---> http://www.youtube.com/watch?v=K9uOS732mdA |
Threads Similar to: Dyno Results
| Some dyno results | Mustang RacR94 | 4V / SVT | 7 | July 29th, 2009 03:25 PM |
| Dyno results | 03SuperchargedGT | 99-04 | 35 | March 4th, 2009 11:12 AM |
| dyno results | 85hatchgt | 5.0 Mustangs | 1 | August 27th, 2008 06:33 PM |
| Dyno Results! | hardhitter | 99-04 | 45 | July 21st, 2008 12:41 AM |
| Dyno Results.. | DarkCandy08GT | 2005 - 2010 | 10 | July 6th, 2008 01:21 PM |
