2001 Mustang COBRA
13.39@106.36
Leaking brake fluid from my clutch pedal??
I just noticed oil all over my carpet and clutch pedal. can anyone show me a do it your self process of fixing the clutch master cylinder ? or tell me how to fix it? thnx
Priest of the Car Gods
You don't have a clutch master. All '79-'04 manual transmission mustangs use a clutch cable.
sounds like its time for a brake master cyl
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences 02' GT ~ Twin Screwed 469hp/493tq |
2001 Mustang COBRA
13.39@106.36
should i get a new factory brake master cylinder or are their any aftermarket ones that will be better for hard driving ????
I know they have clutch cable but the pedal has a part that goes into the master cylinder through the firewall. I dont know what it does either i didnt think the master cylinder was involved at all with the clutch. but it is. ?? |
April 2012 ROTM
we have a cable that engages/disengages the clutch...there is no type of fluid involved. Sounds like a master cylinder problem to me...unless you have a mechanical oil pressure gauge in the car and the line leading to the gauge decided to give up
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
2000 Gt
N/A
What color is the fluid? If you have brake line leak than your brake pedal should be spongy and or go all the way to the floor, hows the brake fluid level, test the stopping of your car, if it doesn't stop in a straight line, then you found your prob. Brake fluid is clear by comparison to power steering fluid. Just FYI
2001 Mustang COBRA
13.39@106.36
its coming from where the clutch pedal is going into the master cylinder? their is a metal rod connected at the end of the pedal it has a boot around it and their is break fluid coming out of it.
2001 Mustang GT
dude. the clutch does not go to the master cylinder.. the clutch pedal connects to the quadrant which is actuall kind of right above the brake pedal, and this is where it passes through the master cylinder. Your master cylinder is actually right above and behind the firewall in respect to the clutch pedal, but the clutch has nothing to do with the brake fluid or fluid at all.
Comp Stage 1 cams & springs, trickflow 70mm tb/plenum, steeda UDP, MAC l/t headers w/ DMH Performance Exhaust Cutouts, Spec stage 1, MGW shifter, SCT tuner, and JLT CAI!
MM's Official Lucifer
Yeah... what?
Hooo Ha Ha
If it does, show us some pics so we know what your talking about. Take a few with a camera or find some online
![]() 410rwhp 520rwtq @ 12.9 psi |
2001 Mustang COBRA
13.39@106.36
i know i just found out its where the CLUTCH pedal attaches to the hydra booster or (Brake Booster) . which turns out uses powersteering fluid so if now someone understands my problem pls let me know any info on how to fix im not sure if i should replace the hydrabooster itself or if their is a seal kit so i can repace the seals.
Threads Similar to: Leaking brake fluid from my clutch pedal??
| Leaking transmission fluid and plastic bag? | oannamarie | 96-98 | 4 | October 12th, 2009 04:49 PM |
| this sucks, leaking tranny fluid | outlawzracing | 5.0 Mustangs | 16 | July 8th, 2009 07:45 PM |
| Clutch and brake pedal placement | homebrewed | 5.0 Mustangs | 0 | June 5th, 2008 05:19 PM |
| Brake pedal gets stiff when A/C is on? | throwedoff | 99-04 | 1 | June 22nd, 2007 10:51 PM |
| leaking differential fluid | cobralini | 5.0 Mustangs | 4 | May 21st, 2007 01:35 PM |
