2001 cam help
Old March 30th, 2010, 07:16 PM   #1
JbLittle86 is on a distinguished road
2001 cam help
Hey guys, im new to the site. I have a 2001 GT 5 speed, 3:55 gear, Professional Products 75mm TB and plenum, X-Pipe with Flowmasters, K&N CAI, and Predator tuned. i want to put in a new cam and intake and im looking for suggestions, type of cam, do i need new springs, etc... It is an everyday driver so im not looking for anything crazy but i would like to get to the 300rwhp area or as close as possible.
Old March 30th, 2010, 07:19 PM   #2
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Well cams are the way to go. I think (correct me if im wrong) you can get hitech stage 2s and run the stock springs.
Your intake manifold is fine. There accualy very very good.
410rwhp 520rwtq @ 12.9 psi
Old March 30th, 2010, 07:21 PM   #3
BYAHHHH!
Scott2001GT's Avatar
2001 Mustang GT
13.874
ok...most, if not everyone will say "keep your stock intake the flow fine" so there's that
Cams...yes hitechs dont require springs but if your there might as well. But a good N/A stage 2 cam will be good for you!
CMS
Comp
Crower
ect.
Old March 30th, 2010, 07:21 PM   #4
ajm
Keep the factory intake.
Get valve springs. Doing cams w/o springs is like pokin a chick w/o a rubber and still pulling out. Just kinda defeats the purpose.....Why have a cam thats gonna allow you to make power up to 6k+ but springs that crap out and limit you at 5400-5500?
Scott pretty much covered all the ones to look into that are well known/have good results.
Old March 30th, 2010, 07:25 PM   #5
2001 Mustang GT
realrider88 can only hope to improve
so stage 2 means you need better springs? wat does stage 1 and 3 mean then?
Old March 30th, 2010, 07:27 PM   #6
ajm
"wat does stage 1 and 3 mean then?
Nothing, a stage is just a reference number...it means nothing at all. Its a simple way for the company to label their cams from least to most radical.
Generally speaking though yes stage 2 cams need valve springs.
Old March 30th, 2010, 07:53 PM   #7
fugie's Avatar
1999 Mustang GT
fugie is on a distinguished road
2001 cam help
I am running the comp cams xe270 grind in my car, cams have a great sounding idle and cams pull hard to about 6000 rpms. I also used the comp cams required valve springs. I also agree why put in perf cams and run the stock valve springs!
Old March 30th, 2010, 08:27 PM   #8
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i have the hitech cams and like. you should get 290-300 with FULL bolt ons including longtubes. and btw i have stock springs and it was ran up to 6300 on the dyno several times with absolutely no problems or signs of valve float. runs like a champ.
cams + 150 shot
Old March 30th, 2010, 09:54 PM   #9
I Blumpkin Entirely Way Too Much
Dolbs4082's Avatar
2005 Mustang GT
Dolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really niceDolbs4082 is just really nice
I've got the comp 270 as well. and my car stopped creating power at 5800 rpm on the dyno so they are def good cams, but i would like to see more rpm personally... i've got stage 2 heads and better springs and thats where mine pooped out haha
MM + Cleavage member #22
Old March 30th, 2010, 11:47 PM   #10
jdos1's Avatar
11 Mustang GT
12.86@109 on 275/40r17 radials hitting 5th gear on the top end.
jdos1 will become famous soon enough
Send a message via Yahoo to jdos1
Would you have to get new cam gears?
Also would getting any stage of cams require a dyno?
Camber Bolts $20 ship OBO!
2011 5.0, 2nd MT82, 3.73's, Amsoil SS 10w-30 & MTG, GT500 A/B, Barton Bracket, BBR Billet LCAs, JLT Separator, FRPP Strut Tower Brace, BMR Springs/Adj Panhard Rod/LCA relos, Koni Sport Shocks/Struts, GT500 USM's
Old March 31st, 2010, 12:19 AM   #11
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
Why gets cams and leave the tune, can't take advantage of maybe 20% of the power increase if that.
My car ran like absolute shit before I got it retuned. Died all the time, sputtered. Just do it right, get springs and a tune. If you need the tool I have one for sale. Just don't drop a valve like I did . Thanks again ajm
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old March 31st, 2010, 12:20 AM   #12
01MGGT has a spectacular aura about01MGGT has a spectacular aura about
I am running CMs stage 1 cams with stock springs. These are very close to hitech stage 2. I love the power! Do need a little more gear to get in the powerband quicker but above 3500 they pull like crazy! Was able to tune them using just the delta force software.
375hp 380tq
Vortech v1 7.5 psi CMS stg1 Cams 75mm TB/Plenum Flows O/R X AFM MrFreeze Meth Steeda Springs Sniper
vids
http://www.youtube.com/user/01mggt
Mineral Grey Club member #14
Military Crew E-4
Predator Crew Chief Holloman
Old March 31st, 2010, 12:25 AM   #13
SteviGX's Avatar
I definately agree with you on the gear. I just got my 3:73's this past weekend and almost wish I had done 4:10's just to hit it quicker. We will see how she does at the track.
Basically it comes down to what you really want out of cams, choppy idle...midrange power, upper rpm power. Every cam is going to give you different power bands and ranges. Just pick the one that is going to give you what you are wanting because you are always going to get different opinions.
Old March 31st, 2010, 12:35 AM   #14
jdos1's Avatar
11 Mustang GT
Well...since they require tunes, I'm definitely not gonna scratch up $500 for a dyno tune...so cams are out of the question until I'm out of school
Old March 31st, 2010, 12:49 AM   #15
SteviGX's Avatar
I've got a mail order tune man. Yeah, you are going to get the most out of a dyno tune, but a mail order tune as long as you get it tweaked will be fine. Nothing in this game a cheap.
Old March 31st, 2010, 01:12 AM   #16
email tune for me too
375hp 380tq
vids
Military Crew E-4
Old March 31st, 2010, 06:54 AM   #17
ajm
Count your valve cover bolts. 11 = no need for gears 12/13 = need for gears, spacers, and washers. Good idea to replace the bolts no matter what since theyre TTY.
No need for a dyno tune for a cam that isnt extremely wild an email tune from a good place will do fine. Funny part is the email tune when I was NA (cams and few other odds/ends) was better than the dyno tune for when I went to FI.
Old April 1st, 2010, 12:12 AM   #18
jdos1's Avatar
11 Mustang GT
Yay! This means cams may be in the works...
Old April 4th, 2010, 02:45 AM   #19
Thanks for the input!! i think i have it narrowed down to either the Hitech Stage 2 or Comp XE262H
Threads Similar to: 2001 cam help
Early 2001 vs. late 2001 huggy bear 99-04 35 March 31st, 2010 12:43 AM
Cam installation - Comp cam stage II Dolbs4082 99-04 4 February 28th, 2009 10:36 PM
2001 s281 hood for 2001 gt? GTSilverBullit 99-04 2 October 13th, 2008 11:43 PM
E cam or F cam horsepower and 1/4 mile time questions GreyGhost 5.0 Mustangs 1 August 21st, 2006 06:25 PM
