Possible Rod Bearing... Help
Old April 4th, 2010, 04:20 AM   #1
jrobinsonchicago is on a distinguished road
Watch the videos below for the sound...
Scenario - I'm getting a ticking / knocking noise from cylinder 8. I originally lost a lot of power, which I thought was due to the tick. I ran the codes and had a misfire in cylinder 4 and 7.
So I replaced all of the plugs and coils. Runs great now. However the tick is still there. Even when I pull the connection for cylinder 8, the tick / knock remains.
I thought if it were a rod bearing the tick / knock would stop when pulling the electrical connector on top of the coil.
The plug has not blown out either. I'm stuck. Any suggestions as to what it could be?
Tick starts at 1:03
Ignore the loud power steering... listen for the tick
My Motor...
Old April 4th, 2010, 11:51 AM   #2
Mustang03's Avatar
2003 Mustang Gt
N/A
Mustang03 is on a distinguished road
yeah buddy i hate to say it but it sounds like a rod knock. i had a bad one on my 98 gt and it got so bad that the bearing just shredded and locked up my motor.
Old April 4th, 2010, 11:59 AM   #3
red01's Avatar
red01 is on a distinguished road
Your about to throw a rod. I had the same thing happen on my car. It started as a low tick and over the course of about 3 weeks got louder till it just let go on my way home from work, worst sound ever! I guess it was a good since I got to replace it with a nice low milelage PI motor, its fun to drive now and I cant stop modding it.
1997 Mustang GT
04 PI 2V, bolt ons, gears, tune
255/292
www.covertmotorsports.net
Old April 4th, 2010, 08:34 PM   #4
NomadGT's Avatar
NomadGT is on a distinguished road
I would say the is idle is affected as well as power issues then I'd look toward a lash adjuster, as this is a common part to fail on the 4.6L. Ford had issued a fix for the famous tick, by putting shims under the adjusters. Run a compression test on the cylinders to make sure. If the rods are in need of freshing then I would say get a full refresh as bearing material has circulated threw the engine.
Old April 4th, 2010, 08:45 PM   #5
TheUNZippee!'s Avatar
A rod bearing has spun, and the bottom end needs to come apart and have new bearings and such replaced.
Continuing to run the motor in this condition could result in seizure of the spun bearing, which could cause a connecting rod to snap in half and thus cause catastrophic damage to the engine block.
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old April 7th, 2010, 11:35 PM   #6
pea_jay's Avatar
2000 GT Vert
pea_jay is on a distinguished road
OK, im speaking from experience on this one. Its a spun rod bearing. JUST going through the same thing as you. Here's a vid from when i took it apart
Threads Similar to: Possible Rod Bearing... Help
sounds just like a spun rod bearing.... 2006greyGT 2005 - 2010 8 March 24th, 2010 06:57 PM
Spun a rod bearing, found a motor.... Tmac3320 99-04 9 October 4th, 2009 10:02 PM
Does anybody know the inner tie rod to inner tie rod lenght on a mustang? Volvo Heretic Modular Mustangs 0 August 28th, 2009 04:36 PM
Anybody know the inner tie rod to tie rod widths of Mustang racks Volvo Heretic All Other Vehicles 1 August 28th, 2009 12:05 PM
rod mpboy 99-04 0 January 31st, 2008 12:41 PM
